2004r
Old Jan 16, 2004 | 11:56 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
2004r
I couldnt find too much about running a 2004r with a tpi ecm. Anyone ever done this here?
Old Jan 17, 2004 | 12:33 PM
Guest
Guest
Posts: n/a
Doing it now. IIRC the pins for the TCC are in different spots, but its pretty simple to change.
Oh yea, and there's no provisions for the VSS, so you need the kind that is mounted on the gauge cluster, not on the trans tailshaft.
Old Jan 17, 2004 | 01:16 PM
shaggy56's Avatar
Car: 71 Nova
Is the VSS something I can pull from the donor car. I think the Car is an 88 Monte SS.
Old Jan 17, 2004 | 09:52 PM
Guest
Guest
Posts: n/a
Other way around, needs to be from an F-body. Yours might have that type anyway, depends on the car and year.
Old Jan 20, 2004 | 09:36 PM
TPIMonteLS's Avatar
Transmission: Automatic!
I am using the original 200-4r in my 87' LS with the TPI setup and no issues at all. Did all the wiring splices at once, but it works just fine.
The VSS is the original one as well, mounted to the speedo....no provisions there. Everything works as it should.
customblackbird
Oct 1, 2015 04:30 PM
dgdinwiddie
Sep 12, 2007 04:58 PM
cc 82Z-28
Nov 17, 2004 08:09 PM
fly89gta
Jun 7, 2001 12:57 AM
