Whats a good cam for my combo?
Old Jan 28, 2004 | 02:13 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
I think when my tax return comes back, I'm gonna replace the cam I have now with something with a little more lift.
Right now I have a Summit 1103 cam:
214*/224* duration at .050
.442/.465 lift
112 LSA
My current setup is as follows:
350 w/ stock bottom end (w/ the exception of hyper. pistons)
WP Sportsman II heads w/ dual springs good up to .600 lift
Pro Magnum 1.52 full rollers
Holley Stealth Ram w/ stock TB and 24# SVO's
Auto tranny w/ stock stall but don't let this play a factor, I should be swapping in a T56 by summer
3.23 gears out back.
Old Jan 28, 2004 | 02:44 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
If you have hyd. roller lifters, then my cam would work well in your motor: Comp Cams XR276HR-12
.503 / .510
224/230 @.050
112 LSA
108 ICA
Old Jan 28, 2004 | 02:51 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
this is the one i have...
08-502-8 Comp Cams "Extreme" Hydraulic Roller Camshaft
218 / 224, .495 / .502 112 LSA - 1500-5500 RPM range
though i would have gotten this one if i had an 2400 stall converter...
08-503-8 Comp Cams "Extreme" Hydraulic Roller Camshaft
224 / 230, .502 / .510 112 LSA - 1800-5800 RPM range
with the second cam, you'd have a problem with cam surge at idle or low rpms unless you have a 2000+ stall converter.
since you're going to go with a HSR, i'd say to get the 503 cam once you get yourself a converter.
call up comp cams at 1800-999-0853 and tell them what setup your going to run and they'll recommend a cam to you. when i called and asked the guy about what cam i should use for the MR i plan on putting later on, he told me to get the 503 because you really dont wanna spin the engine higher than 6 grand. but whats the point of having the MR or the HSR if your not going to shift at around 6, 6 1/2 grand? lol
Old Jan 28, 2004 | 02:55 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
forgot to add, I don't have a roller motor. Just plain old flat tappet lifters.
Old Jan 28, 2004 | 04:14 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Comp makes the .503 cam in a flat tappet grind.
Old Jan 28, 2004 | 05:05 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
If it were me I would switch to a roller. I would get the LT4 GM Hotcam, with GMPP roller lifters, and GMPP 1.6 roller rockers. The cam with the 1.6 rocker is as follows:
218/228 @ .50" dur, .525"/.525", 112 LSA :hail:
Your car would do alot more this then...
Just my .02 though.
Old Jan 29, 2004 | 09:50 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
The hot cam is weak. It's kinda funny that everyone thinks it's the greatest thing since sliced bread.
Yes, there are worse cams out there, but GM made the LT-4 hot cam on the conservative side for a reason. They trade a little power for a little reliability and to work a little better with stock ECM programming.
There are better cam choices for his Stealth-ram combo is all I'm saying.
Old Jan 29, 2004 | 12:32 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
I agree with that, I bet a lot of cars running the Hotcam and any decent aftermarket head are leaving a bunch of power on the table by going too mild. Id go with the XR276HR.
Old Jan 29, 2004 | 12:48 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
i wouldnt go with the XR276HR unless you had a 2400 stall ... ur gonna experience cam surge with a stock converter
Old Jan 29, 2004 | 01:15 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
I can deal with that until I get my T56...
I refuse to drop any more money in this slushbox
Old Jan 29, 2004 | 03:09 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I thought you were selling the car?
Old Jan 29, 2004 | 04:05 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
I've been trying but no one seems interested.. got nothing but a bunch of "Hey, would you trade for a 92 corsica w/ a blown head gasket and $500?? :insert ignorant teenage smiley face:"
SURE, WHY NOT
customblackbird
Aug 15, 2021 10:16 PM
1984HO
Mar 19, 2021 11:59 AM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
