Best way to disable a cold start valve?
Old Feb 17, 2004 | 12:29 PM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
I need to disable my cold start valve and I have seen pics of people who have done it, but I'm not quite sure exactly how to do it. Anybody done this? If you haven't removed it and plugged it, then what would be another good way to disable it?
Old Feb 17, 2004 | 04:31 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Why do you need to disable it?
Old Feb 17, 2004 | 05:58 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
my guess is he is swapping to a 730 SD ECM
Old Feb 17, 2004 | 06:41 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
Easiest way to disable it is to pull the plug on the injector itself or on the thermo switch on the intake. Also anyone know of a good blockoff kit for the injector hole in the intake as well as a cap for the end of the fuel rail??
Old Feb 17, 2004 | 11:11 PM
Accel makes a kit to plug the hole. I wouldn't unplug that switch. It is also usede for fan control, so unplugging it may render your cooling fan(s) inoperative.
Old Feb 18, 2004 | 01:05 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
You can buy them on ebay or several performance shops online. I just kept mine connected but unplugged the injector itself.
Picard out...
Old Feb 20, 2004 | 08:20 PM
Car: 85 Z28
Engine: 383 Stroker
I need to disable it to because I bought a super ram and there is no hole in it for the cold start injector.
Old Feb 21, 2004 | 04:57 AM
MIDNITERIDER's Avatar
Car: 1988 Formula 350
Transmission: 700R
Axle/Gears: 9 Bolt...3:27
I cant seem to find the block off kit by Accel. Can anyone provide the P/N??
1988 Formula 350
13.93@99.32mph
Old Feb 21, 2004 | 12:05 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I disabled mine years ago. I used a coin, a quarter I believe, and some sensor safe silicone sealant. I used the coin and the plate that normally would hold the injector to the intake manifold.
I did the same thing with the exhaust tube that use to run from the #8 header pipe to the intake manifold (86 Vette setup). In that case I used a dime.
Both have worked fine for years.
Jake
Old Feb 21, 2004 | 12:07 PM
elcamin0_77us's Avatar
Car: 77 El Camino
Engine: 355 Converting to TPI
Transmission: Converting to 4L60/4L60E
Try Street & Performance at the following Link :
http://www.hotrodlane.cc/
They carry what your looking for.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
