what is this hole for on accel manifold?
Old Feb 20, 2004 | 03:29 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
on the accel manifold there is a threaded hold the comes in from the top on one side of the manifold? it has a hex plug in it. what is this for. the original manifold doesn't have this. it goes in to one of the ports for the runners.
Attached Thumbnails what is this hole for on accel manifold?-picture-014.jpg
Old Feb 20, 2004 | 04:34 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Show a picture of the manifold hole you are talking about, and I'll tell you what it's for.
Nice car, by the way!
Old Feb 20, 2004 | 07:09 PM
1992rs/ss's Avatar
this is the best pic I could find, I am in iowa at school and manifold is in IL!!!!!! the hex plug comes in the way the arrow points.
Old Feb 20, 2004 | 08:37 PM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
it looks like the cold start injector hole, but it looks a little small in the picture. That is the same place it is on the stock manifold though so I'm assuming thats what it is for.
Old Feb 20, 2004 | 09:12 PM
Guest
Guest
Posts: n/a
Thats not cold start, thats where the fitting for the PCV hose hooks up. Cold start is down and to the left.
Old Feb 20, 2004 | 09:41 PM
1992rs/ss's Avatar
well all I know is that is came with a plug in itthat uses an allen wrench to remove it, the 85 manifold that I have as well does not have this.
Old Feb 21, 2004 | 01:22 AM
1992rs/ss's Avatar
here is another view I found
Old Feb 21, 2004 | 01:24 AM
1992rs/ss's Avatar
here is the pic
File Type: bmp
Old Feb 21, 2004 | 09:41 AM
Guest
Guest
Posts: n/a
The other pic you posted looks like theres another hole up there I didnt see before. Thought you were referring to the one in the side near where the runner mounts up.
Never seen that one before.
Old Feb 21, 2004 | 10:19 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Hole
That's just an access hole to the vacuum. After they drill it they plug it and the vacuum then goes to the PCV fitting from the manifold.
Old Feb 21, 2004 | 01:12 PM
1992rs/ss's Avatar
so I should just leave the plug and no worry about hooking anything up to this
Old Feb 21, 2004 | 06:11 PM
llvll4l2c91350's Avatar
this is the hole that he's talkin about. i didnt know what it was for either.
Attached Thumbnails what is this hole for on accel manifold?-dscn0471-small-.jpg
gta892000
Aug 11, 2019 11:16 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Rally Smith
Sep 14, 2015 06:59 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
