LT1 intake conversion, in progress, on Sportsman IIs
Old Feb 24, 2004 | 08:15 PM
85TransAm406's Avatar
Car: 1985 Trans Am
I got my intake back from the machine shop today, as I had to have .050 taken off each intake face to match up right, as my block and heads have been decked. Here are some pics of the welding that was done to cover the coolant ports completely.
The first one has a line drawn where the aluminum stock was added.
Attached Thumbnails LT1 intake conversion, in progress, on Sportsman IIs-s3000014.jpg
Old Feb 24, 2004 | 08:16 PM
Car: 1985 Trans Am
Here's one from the top, where i haven't cut it down to look right.
Attached Thumbnails LT1 intake conversion, in progress, on Sportsman IIs-s3000015.jpg
Old Feb 24, 2004 | 08:17 PM
Car: 1985 Trans Am
oops, no pic.
Old Feb 24, 2004 | 08:22 PM
Car: 1985 Trans Am
Last one, where I have almost finished.
Attached Thumbnails LT1 intake conversion, in progress, on Sportsman IIs-s3000016.jpg
Old Feb 24, 2004 | 09:27 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
cool... good job.
im going to have to do that for my dart heads too..
im using it as my excuse to get the alum welding kit for my mig welder
did you take any before pics of when it was on there, but not covering the coolent ports?
Old Feb 24, 2004 | 09:32 PM
Car: 1985 Trans Am
You mean like this?
Attached Thumbnails LT1 intake conversion, in progress, on Sportsman IIs-s3000003.jpg
Old Feb 24, 2004 | 11:37 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Looking good, I'm hoping for at least somthing close to that. I had to have my intake welded to cover the EGR ports, and I went ahead and had the guy weld some on top of the coolant ports too while he was there. Never know what heads I'll use in the future. Of course I didn't have that handy picture handy like that one, thanks 85TransAm406. I think He'll probably get enough material on there, but we'll see. He repairs aluminum cylinder heads all day so I can't wait to see how good his welds are.
Old Feb 25, 2004 | 06:01 AM
Car: 1985 Trans Am
I would have had to have material added over the EGR ports if they were opened up also. When my intake was set on the engine it was clear the there was about 1/8" of the EGR port showing, but the intake gasket covers it up, and the ports in my heads aren't drilled through, so no problem for me. I'm not extremely happy with the welding job, but we'll see how it holds up when torqued down. I still gotta figure out how i'm gonna do the bolt holes on top, with the difference in angles. I know I could just grind it, but that's kinda crappy lookin.
Old Feb 25, 2004 | 01:16 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
If you have a drill press with a big enough vice to hold the intake, you can use a Forstner bit. The aluminum is soft enough that it will cut, but if you have a cheap Forstner bit it will be enough to kill it after drilling enough holes with it... It should make it through the intake manifold's amount of holes just fine though...
Old Feb 25, 2004 | 01:36 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
lol, i didnt know what a Forstner bit was, so i did a search.... just thought id share the info... and yea, that could work..
from: http://www.wisegeek.com/what-is-a-forstner-bit.htm
What is a forstner bit?
Drill bits are used in conjunction with hand drills or drill presses to make holes in woods, plastic and metals. A forstner bit is a particular type of drill bit that is often used in furniture making and other woodworking projects. They are usually more expensive than standard twist bits, but they have a few unique features that make them desirable.
Most drills are guided through the material by a central point, but forstner bits are primarily guided by the outside rim. This means that they can be used to drill pocket holes (holes drilled at an angle), partially overlapping holes or holes that are on the edge of the material. Note that the central spur in the bit pictured below is used to locate by demarcating the center-point as opposed to being the drill guide.
In addition to the previously mentioned benefits, forstner bits create square-bottomed holes which may be required for certain applications or projects. They are very efficient at removing large amounts (hogging) of material in short periods of time. Forstner bits are available in a wide array of diameters typically ranging from 1/4 inch up to over 3 inches (6 - 75mm). Like other drill bits, they are often sold in sets with an array of sizes.
Attached Thumbnails LT1 intake conversion, in progress, on Sportsman IIs-forstner-bit.jpg
Old Feb 25, 2004 | 02:35 PM
Car: 1985 Trans Am
i don't know how i'm gonna get to the center holes though, the casting kinda gets in the way of a 90* angle on the center and a couple of the front holes.
Old Feb 25, 2004 | 02:56 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
who says you have to drill the holes from the top down?
im going to flip the manifold over to do mine....
Old Feb 25, 2004 | 04:29 PM
bnoon's Avatar
To drill a recess for the bolt head to sit flat, the Forstner bit must come in from the top silly!!! The part for the threads could be drilled from the top or bottom, but that's not what this thread is about.
85TransAm406, there are long shank Forstner bits to increase your available angle, which may be enough for those center holes... I guess I never looked that closely... I'd better, since that's how I planned on cleaning mine up too, LOL!
Just FYI, Forstner are fairly cheap at http://www.harborfreight.com.
Old Feb 25, 2004 | 06:08 PM
Car: 1985 Trans Am
Yeah, if i can find one with a long enough shank it should be ok. The only problem is where the sides of the casting around the vacuum ports get in the way around the holes. I found this pic on the classifieds, and it looks like he did this and made it work.
Attached Thumbnails LT1 intake conversion, in progress, on Sportsman IIs-convint.jpg
Old Feb 25, 2004 | 09:55 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
You can buy or make angled flat washers in aluminum, stainless or steel from most GOOD hardware stores.
Old Feb 25, 2004 | 10:24 PM
Car: 1985 Trans Am
I was thinkin about that also, do you happen to know the angle?
Old Feb 26, 2004 | 08:12 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
This is the biggest pain in the butt with the lt1 intake swap. I tried the angled washers, didn't look good, and wasn't sure about the clamping force. The only good way of doing it is to weld some material on top of the bolt holes, but then it is hard to machine that surface flat because of lack of space.
Old Feb 26, 2004 | 10:28 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I made a quick webpage on how to properly spotface the intake to allow for the bolts to sit flush on the flange. I have started doing this revision to all new orders since Jan. 2004.
Here's the link
http://www.lt1intake.com/counterbore.htm
Old Feb 26, 2004 | 10:33 AM
Car: 1985 Trans Am
Now that is a good idea. Thanks John.
Old Feb 26, 2004 | 10:55 PM
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
Great idea John, but I already have mine powder coated. I may try it anyway. The washer will cover the scars.
Old Feb 27, 2004 | 01:32 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
has anyone thought about using a allen countersunk bolt for the intake bolts?
Old Feb 27, 2004 | 11:23 PM
Car: 1985 Trans Am
regular bolts work, but the angle of the upper intake flange is wrong, it's not 90* to the intake face. I use the ARP bolts, but John included the allen key bolts with my intake conversion kit.
Old Feb 28, 2004 | 10:44 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
please, completely ignore me.. lol.. i have no idea what i was thinking.
2 posts up from that one, im talking about yea, that sounds great, then i totally missed it.. lol. i think i was thinking about the threaded part...
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
1985chevydude
Aug 22, 2015 05:36 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
