How much power do you think?
Old Feb 25, 2004 | 01:12 AM
snowman89's Avatar
Car: 1989 IROC-Z Camaro
Engine: 5.8L 355
Transmission: T-5 5-speed
Well i'm pretty set on this set up. I know it isn't the best, but I mean its just something that I have to work with. And I just want to know if anyone has any rough Idea on what it could run Horsepower, and torque wise. ok here is the set up
1976 4 bolt main 350 block bored .030 over.
Speed Pro forged pistons.
Eagle I beam rods.
TPI intake off 89 IROC
L98 heads, will be ported, three angled, and other machining.(I wish I had the money for AFR's).
COMP CAM's Hydraulic cam. dur @.050 222/226, lift .464/.464...
Headman Shorty Headers in to custom Y pipe which flows into magnaflow dual out muffler.
MSD Coil, MSD super conductor 8.5 ignition wires....will soon have MSD 6AL.
Custom Computer Chip Burned by PCMforless.
Well if I can come up with the money I would like to Throw HSR on along with it. If I can't get the money for it. I will siamese my intake base, runners and port my plenum.
I know it isn't that great, but I mean thats really the best I could do. besides I wanted to put an engine together. It may not be what I would like but I hope its more than a stock L98 like I have right now. Thanks for you thoughts guys!!!!
tyler
Old Feb 25, 2004 | 02:53 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
If, IF the heads are well ported by a professional you should get
about 350HP and 430 TQ
Old Feb 25, 2004 | 09:42 PM
snowman89's Avatar
Engine: 5.8L 355
You really think I could get that much power out of it? Why do you think so??? I am just curious about it.
what kind of porting should I do or have done. I would like to do it myself. But I bet a shop would be better than me doing it. If it isn't that hard, are there tutorials on how to do it or anything? I'm interested on learning how to do it? But I don't want to mess up these cylinder heads that I will be using.
Old Feb 25, 2004 | 11:04 PM
89Warbird's Avatar
Engine: 389 CID TPI
DD2000 numbers, they will be close. If you are going to port them yourself then know off about 30 HP and 40 TQ, maybe more.
Old Feb 26, 2004 | 01:25 AM
snowman89's Avatar
Engine: 5.8L 355
yeah I'll have a professional do it. will roller tipped rockers help much
what is DD2000?
So if i don't port and stuff, will I atlest be around or above 300hp? 370 TQ????
Old Feb 26, 2004 | 03:23 AM
89Warbird's Avatar
Engine: 389 CID TPI
DD2000, is desktop dyno 2000. As far as porting, it's expensive, and most people don't know how to do it right.
Roller tipped rockers give some advantage the real plus is decreased wear on the top of the valve stem. They are usually higher quality than stock so they don't flex and the ratio is correct. Also they will decrease side loading of the valve which increases valve guide life.
I'll figure up what you get without porting later, no time right now.
Old Feb 26, 2004 | 01:58 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
i need to take mine back to the dyno again...before my current mods i was at 350hp and 480ftlbs but that was with a 5 speed and i kept blowing clutches and third gear out.............now i have an auto with a 3500 stall.....who knows what i got now......
Old Feb 26, 2004 | 07:29 PM
snowman89's Avatar
Engine: 5.8L 355
Yeah I have a 5-speed, and If I get the job that I'm trying to get I will get a T-56. I just hope I get between 330 and 350hp with 400 something torque!!!
Old Feb 27, 2004 | 12:38 AM
89Warbird's Avatar
Engine: 389 CID TPI
WallyZ/28, if you had 350 HP and 480 TQ then I'm assuming this is the calculated number at the flywheel and not at the rear wheels. Changing to an automatic won't change the flywheel numbers. If you are saying you made 350 HP and 480 TQ at the rear wheels, then that's great numbers. Expect it to drop about 5 to 7 percent due to the automatic.
Old Feb 27, 2004 | 11:52 AM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
yeah that was at the rear wheels....the only reason i went to an auto this time was i didn't want to sink anymore money in my t5....i blew 3rd gear out the first time at the track last year.the 350horses and 480 tq were with my last engine setup....but i doubt i have that much now anyways......don't get me wrong...my car feels pretty strong and roasts the tires at 30mph....but i just don't know since i added the runners and hot cam and throttlebody.......i also have a msd 6al since my last visit to the track
Old Feb 27, 2004 | 01:58 PM
89Warbird's Avatar
Engine: 389 CID TPI
snowman89 without porting you get about 305 HP and 420 TQ.
Old Mar 11, 2004 | 09:53 PM
snowman89's Avatar
Engine: 5.8L 355
Ok
Old Mar 11, 2004 | 10:29 PM
snowman89's Avatar
Engine: 5.8L 355
hey warbird.....I had to cancel out the heads that I orinally had planned. They were 305 heads..I found out it wasn't a 350 L98 instead it was a 305 LB9....It was kinda a wierd thing, seeing the guy told me it was a 350. I think he just mixed up. I don't really care. HAHA
So I had a set of 14102193 heads sitting around that I had a machine shop port and polish them for my truck awhile back...what do you think I will run with those heads on????
Old Mar 13, 2004 | 05:26 AM
89Warbird's Avatar
Engine: 389 CID TPI
Standard 305 heads ported and on a 305?
Old Mar 14, 2004 | 07:19 PM
snowman89's Avatar
Engine: 5.8L 355
No they are 350 heads....and I put them on my 355 engine....I just wonder what how they will effect my engine compared to the L98 heads. Which I don't have. But that was the plan, but It turned out I had a 305 in my car instead of a 350. So I had to resort to the other 350 heads I had lying around.
Old Mar 14, 2004 | 07:31 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
The cam is pretty small and the heads arent worked that much....possibly 290HP/310TQ
Old Mar 15, 2004 | 10:15 AM
snowman89's Avatar
Engine: 5.8L 355
well actually the heads have been fully ported and polished, 3 angle valve job, bowl job. Combustion chambers have been cleaned out. They were done really good too. They guy who did them did a good job.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
