Finally, I'm headed off to the dyno, to see what she'll do...
Old Apr 6, 2004 | 08:21 AM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
As the governator would have said, "Ah'll be bach", with the results later this afternoon. Heck, I might even take a couple of videos and post them too, thanks to my new digital camera. I might need some help with that though, I haven't posted a vid. before. Wish me luck.
Old Apr 6, 2004 | 09:57 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Good luck! Man, I hate first dyno runs for new combos. My nerves are always on end!
Old Apr 6, 2004 | 10:02 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Good luck, any estimates?
Old Apr 6, 2004 | 03:09 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Well guys, here's how it went down. Me and my dad both had are cars dyno'd. After all, I only got one good run and my dad got two, because the tach hookup on the dyno wasn't working the other five pulls, so I just said, "That's it". Another problem or should I say two were the dynojet had a glitch in it's software, so the graphs were all messed up and I don't have the rpm's where my peaks occurred. The other problem was the wide band was messed up at this shop. Jeff, the technician was a great guy and you could just sense his frustration as much as ours. He was truly dissappointed that we couldn't get any more runs on mine after I played with the FP and the timing. Anyway I do have a good baseline and I'm sure 400rwhp is right around the corner, when I get my overly rich problem figured out. The other figures were from my dad's camaro that's messed up, cause it only put 256rwhp down. My car was so rich that it was backfiring out the exhaust as the rpms started to decline, so it was definitely dumping gas in. I've got a video, so I'll post it later.
Attached Thumbnails Finally, I'm headed off to the dyno, to see what she'll do...-dynosmall.jpg
Old Apr 6, 2004 | 03:22 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Guys tell me how to load an 18mb video, it ya want to see it. I can't seem to put it on the board even when I compress it???
Old Apr 7, 2004 | 11:38 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I think it put down 386 hp and 383 tq before the motor went.
What did you change?
Old Apr 7, 2004 | 12:30 PM
bnoon's Avatar
You'll have to FTP the video file to your hosting service, then post a link to your URL address and file name. You can only attach picture files to the BB, not video files.
Old Apr 7, 2004 | 03:23 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Nothing was changed, except I bumped the compression up to 12 to 1 and I actually put the correct valve springs on this motor. Remember I only got one baseline run, no tuning has been done. The dyno wasn't working hardly at all, it kept showing no signal on my tach and it did the same with my dad's car. The motor also isn't even broken in it only has about 325 miles on it. The dipstick is blowing out everytime I punch the gas because of all the blowby. This motor is running strong, but it has a lot left in it. It was running so rich on the dyno that there were flames coming out of the exhaust when the operator left off the gas from 7 grand. That's how rich it is up top. I need to get the rest of the tuning equipment and software for my laptop asap. I think there's another 30-40rwhp to be gained easily. This would put me at my 525-550 hp mark, which I figured my engine would produce. The 700 trans is also know to reduce power from 20-25% of your fwhp, so I'd say that so far the engine is doing good. At least I like to think positive after all the stuff I've been through.
bnoon, what's my hosting service?? Sorry, I'm not familiar with that term.
Old Apr 7, 2004 | 06:20 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Great numbers for no tuning dude. I bet you pick up a decent amount once you get it tuned right. Congrats!!!
Old Apr 8, 2004 | 10:59 AM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Here's a pic of the car...If anyone wants me to email you my video so you can post it I can do that let me know. The car sounds wicked that's the main reason I want to post it.
Attached Thumbnails Finally, I'm headed off to the dyno, to see what she'll do...-cardynosmall.jpg
Old Apr 22, 2004 | 01:37 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Sounds like you are heading in the right direction. I am guessing mine will be right in the same neighborhood as yours when it is all said and done. I don't have as much compression as you though (10.7:1) so it might be closer to the 525 figure, but I am also a bit optimistic as the CNC'd Brodix Track 1 heads have some crazy flow numbers (beat AFR 210s throughout all lift levels).
I'm screwing around with my PROM right now and I seem to be chasing my tail some but I hope to get to the dyno within the next couple of weeks once the part throttle stuff is all dialed in. I've got an LM-1 wideband O2 and for some reason it is telling me that my car really likes to just sit around 14.0:1 at idle and part throttle and it isn't real happy about moving from there - regardless of what I change in the .bin. Kind of weird really.... never had this problem before. I'm going to get a fresh copy of the Super AUJP .bin and start over from scratch just to make sure I don't have some weird stuff going on with my file, but if this condition continues I am going to have to get some help with tuning this....
Old Apr 22, 2004 | 09:35 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Thanks for the reply, Matt. I try and keep up w/your web page to see how the car's doing. Yeah, your heads are awesome, but I know mine aren't exactly a bottleneck since they were ported by TEA and flow 300 cfm.
I think you'll be at 400rwhp easily since you're familiar with chip tuning. I'm hoping to be there as I've done some research and found out my car's knock sensor is throwing a code, even on my dyno run, so the computer is in effect retarding timing between 7-11 degs all the time, so there's no risk of danger to the engine. Right now my car is at my friends awaiting some battery cables, since the positive grounded and nearly burnt my car to the ground. I'll have him check out the knock sensor problem then, but I'm almost sure that the ks wire got toasted by the header. I'll see in a few days, but I do believe that this spark retard is what kept me from my 400rwhp mark.
Old Apr 22, 2004 | 09:49 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Gotta love those TEA ported heads!!! Great group of guys and Brian knows his stuff...
Old Apr 28, 2004 | 12:00 AM
OMINOUS_87's Avatar
Hey Joe clean out your PM box.
Old Apr 28, 2004 | 10:59 AM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Okay done. No wonder I wasn't getting written back...
Old Apr 30, 2004 | 07:50 PM
LETHALRACER's Avatar
The 386/383 were the corrected numbers on the stock converter. It went 408/405 uncorrected. But when the Vig was a 4,000 it went 350/450 corrected with about 10.0:1afr if I remember correctly. There is a lot more left. Plus the head flow more towards the nitrous side than the NA side. I will say 430/460 when all said and done. It will be a monster. Low elevens at 123+ for sure.
Old May 1, 2004 | 10:00 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Hey Brett, thanks for the kind words. I've been wanting to say that I'm sorry for talking all that smack a few months back, but I'm sure you know know how I felt after what happened. I almost got into a fist fight with the old man over the whole ordeal, if that tells you how pissed I was. Hope there's no hard feelings, I still got a deal on the car considering everything. I'll let you know how it turns out performance wise.
Old May 2, 2004 | 12:29 PM
vwdave's Avatar
Kill this post.
-Dave
Old May 2, 2004 | 05:18 PM
No hard feelings here man. I kind of ended up in the same situation with the 69. It turns out that it has a bent frame. No big deal but I should have checked it out better but I got excited and am paying the price now. The funny thing is that some one worked on the frame to get it straight enough to sell. They carefully painted it and every thing. So he can't say he didn't know about it. But oh well, live and learn. I hope the car treats you as well as it did me now that you have every thing worked out. It will have to run better if all that stuff was corrected that you said was messed up. Good luck and keep us updated. I just want to see you best my old times.
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Polo Z03
Sep 10, 2015 06:43 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
