code 32, getting frustrated
Old Apr 7, 2004 | 08:59 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
well i had replaced the egr valve, i bought it used, could it be that the used one i bought is not working properly? , i replaced it and disconnected the battery to clear the code, now two days after i get it again, only happens sometimes in the highway, its starting to frustrate me, is my computer just freaking out? my car has no problems whatsoever, like my uncle saids(mechanic) if the car doesnt give you ****, dont worry about it
Old Apr 7, 2004 | 09:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you check the EGR solenoid and the vacuum lines? I know this chart is for a 2.8L, but a lot of the basics are the same.
Old Apr 7, 2004 | 09:29 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old Apr 8, 2004 | 12:01 AM
Car: 1990 firebird
Engine: 3.1 v6
your da man trickster, now i just need to find some stupid mechanic to do this for me, i figure if the ones i went to didnt know how to do this they shouldnt be a frigging mechanic. thanks alot, im printing this out, gona go see who will be the lucky one to do this for me
btw where did you get this at?
Old Apr 8, 2004 | 06:24 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I got it out of the GM service manual for my car.
Old Apr 12, 2004 | 02:51 AM
Pat Hall's Avatar
If you did a search on code 32, you'll find it's probably the most commonly occuring problem on these cars. In other words, it's a damn PITA. I know I'll be accused of heresy for this, but I fixed mine the "old school" way and just plucked the service engine bulb out. My cars runs perfectly fine even though it throws the egr code once in a while, so I figured what's the difference? BTW, I did this as a last resort after replacing the egr valve, checking the solenoid, vacuum lines, etc. Probably the only other way to fix it on my car would be to remove the intake manifold and clean out all the egr passages. I decided plucking the bulb was way easier than removing the intake manifold!
Old Apr 12, 2004 | 08:17 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I recently replaced my EGR solenoid, valve, and harness.
I still get a code 32 when the engine starts (cold).
But, if I shut it off (once its warmed up) and then turn it back on, the check engine light stays off.
I'm running out of EGR things to replace
Old Apr 12, 2004 | 01:34 PM
Car: 1990 firebird
Engine: 3.1 v6
eh that makes me less worried, the car doesnt give me problems, runs great, cept for the shutting off when its to cold thing, im impatient, but hey i guess 3rg gens didnt perfect this egr thing
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
