The 4500 Power Loss
Old Apr 9, 2004 | 10:16 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
The 4500 Power Loss
Im on a 400 dollar budget, what should i get to get rid of the power loss? Thanks guys
Old Apr 9, 2004 | 10:23 PM
87350IROC's Avatar
Car: 87' IROC
are you stock now?
Old Apr 9, 2004 | 10:30 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
yeah. bone stock, any suggestions?
Old Apr 10, 2004 | 04:35 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Headers and a catback will relieve a small amount of the top end loss, but that is already outside 400 bucks... most economically, you can invest in a dremel and a bit set. With that - you can slowly port out the plenum, match the runners, and port the base a little. That will do more for the topend than exhaust work, and you can essentially DIY.
Old Apr 10, 2004 | 03:18 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
how about cap, coil, rotor? or afpr? would that help?
Old Apr 10, 2004 | 03:54 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
no, no, no, & no.
The 4500RPM cliffhanger is because the TPI system chokes at that point of demand. The only way to relieve it is to improve the flow of the TPI. You can port your stock stuff (good), or port aftermarket stuff (better).
Old Apr 10, 2004 | 03:58 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
oh ok, cause when i gun it on my blue iroc it goes all the way to 5200 no problem, but with my white one i gun it and it just goes 4500, so was there a big change with the 88-89? i mean both of them are stock, but i guess the 89 was a better car then
Old Apr 10, 2004 | 08:35 PM
87350IROC's Avatar
Car: 87' IROC
what year is the other one? and is a 350 too? its possible something isn't right like timing for ignition stuff, but it sounds to me like the normal tpi brick wall. Maybe the previous owner has done some work to the other one. Exhaust would be best but like said a good exhaust will run more than $400. You also could look at SLP or comparable runners.
Old Apr 10, 2004 | 10:29 PM
Morley's Avatar
Somethng isn't right there. It should rev past 4500 RPM, the "brick wall" people speak of at 4500 is power, horse power falls off rapidly after 4500 RPM, but the engine will go beyond that point.
theshackle
Sep 17, 2020 08:26 AM
formula_novice
Sep 5, 2015 03:58 AM
Warlocksirix
Aug 29, 2015 11:36 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Bradsaundry
Aug 12, 2015 12:34 AM
