large hei distributor to small hei?
Old Apr 12, 2004 | 05:33 AM
pontiacpete's Avatar
has anyone changed over? if yes where did you obtain the connectors ? can you buy the pigtails new? if possible gm part numbers would be appreciated also a diagram with the wiring of the changeover would be great thanks
Old Apr 13, 2004 | 01:28 AM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
give these guys a call:
http://www.hotrodlane.cc/
They make a large-cap- to small-cap HEI wire adaptor that plugs into the 4-wire connector on you harness as well as the distr. to coil wire and the coil power/tach wire (3 pieces total).
Old Apr 13, 2004 | 02:03 AM
just the info i needed thanks a million
Old Apr 13, 2004 | 03:00 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
$0.50 at the junkyard for the connectors, and 5 minutes of soldering and shrink tubing. Of course I had to cut the stock connecting plug off, but I'll never want to go back anyhow.
Old Apr 14, 2004 | 04:13 AM
wish i had the luxury of having a gm wrecker down the road but unfortunately no chance here down under
Old Apr 14, 2004 | 07:45 AM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Oops, lol, I didn't notice that!
Old Apr 14, 2004 | 08:32 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Did the wiring colors match up from old to new, or did you have to have to cross check the electrical diagrams for the new connectors to work?
Old Apr 14, 2004 | 09:04 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Wire colors are the same.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
