Problem with the IROC Need opinions...
Old May 28, 2004 | 10:40 AM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
All of a sudden while in it today while driving it started stumbling real bad like it was running out of gas, unburnt gas smoke coming out of the exhaust so I assume it's electrical in nature. Tried pulling a code but only got code 12 tapped the maf sensor but no help there either. It's weird cause it can run fine for a few minutes either idling or driving then all of a sudden die or attempt to die, with the unburnt gas fumes/smoke.
My 1st guess after it showing no codes is computer is going....
Anyone agree/disagree with this?
Old May 28, 2004 | 11:33 AM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
Try some dry gas. I dont know what theyre doing to the gas in my area last couple years every time i let it get below a quarter tank of gas it starts stalling and smoking like a pig. As soon as i fill it up and dump a can of dry gas in it its back to normal. If the car sits in a damp garage this might have something to do with your problem.
Old May 28, 2004 | 11:37 AM
Dano 00TA's Avatar
Engine: LS1/L98
The car has a full tank of gas in it and sits outside. It ran fine when I drove it 2 days ago, just started screwing up this morning
Old May 28, 2004 | 02:45 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
try disconnecting the maf sensor and firing her up. let the ses light come on. see if it runs better.
Old May 28, 2004 | 03:11 PM
Dano 00TA's Avatar
Engine: LS1/L98
Did better than that, I have a brand new maf that's been laying around and tried it. No better. When I first started it it ran fine for a couple minutes, then it started acting up again, now it won't even stay running and I noticed with the key on and the car engine off the check engine light flashes randomly, almost as if it were shorting out flashes fast then slow than stops flashing, etc.
Old May 28, 2004 | 03:46 PM
Car: 1988 IROC-Z
replace the ecm. at the least swap it, with a good used one. that maybe the answer to your problems.
Old May 28, 2004 | 04:00 PM
Dano 00TA's Avatar
Engine: LS1/L98
Yeah, with the randomly blinking check engine light I'm more and more taking this to be my problem.
Thanks for the help
Old May 29, 2004 | 11:20 AM
Dano 00TA's Avatar
Engine: LS1/L98
Well, it's confirmed to be a bad computer. Yanked the computer apart and layed it on the floor, started it up and as soon as I tapped the ecm the car died. Going to get a new one right now.
Old May 29, 2004 | 12:07 PM
Car: 1988 IROC-Z
glad to hear the problem will be resolved soon.
Old May 30, 2004 | 08:38 AM
Dano 00TA's Avatar
Engine: LS1/L98
All is good now, got the new computer and it's running great again:lala:
Old May 30, 2004 | 09:06 AM
Car: 1988 IROC-Z
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
