IAC won't adjust, need help
Old Jul 10, 2004 | 07:57 PM
dwillms's Avatar
Car: 90 Integra
Engine: B18
Transmission: 5-speed
Hello,
Since I've had my car for the past 3 years or so, it has always idled high. When I first got it, around 1300 RPM, tried adjusting IAC, now 1000-1100 RPM.
So today I finally decided to try again. Followed correct procedure listed on the boards here. (BTW, my TPS is set perfectly, if that makes any difference). I can't get my car to start AT ALL when the IAC is disconnected. No matter how far in or out I turn the adjustment screw, it won't start.
Now, my car idles high at start, but when it is warm, it idles low enough that it almost stalls (500-600 RPM I believe). I know the ECM controls idle, but I still think there is some reason it is idling that high.
Is it my actual IAC valve that is causing me problems? I have cleaned my throttle body blades.
-Dustin
UPDATE: Tried to do the procedure again when the car was at normal operating temperature, still didn't work. Now, I reconnected my IAC, and my car now won't even start anymore. Issues...
Old Jul 10, 2004 | 08:41 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are you following the procedures in the article that VADER has posted in the tech article section?
Old Jul 10, 2004 | 09:07 PM
dwillms's Avatar
Car: 90 Integra
Engine: B18
Well, about 3 sentences in, anyways I jump the ALDL, wait 30 sec, disconnect IAC, take out paper clip, try to start car. As soon as I disconnect the "connector" from my IAC, and try to start the car, it won't start.
Also, I tried adjusting the IAC screw to see if that would make any difference in starting the car, but it didn't do anything, no matter what I did to it.
I waited about half an hour, now tried to start the car, it runs with IAC connected. Idles about 1000 in Park, about 800-900 in Drive.
-Dustin
Old Jul 10, 2004 | 09:20 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That screw that you were turning is the Idle Speed Adjustment screw. That is what you turn after you have the car running with some one in the drivers seat holding the brakes and the car in gear. By turning it, you are throwing the TPS setting way out the door and the ECM is trying to compensate for it. Turn the screw back to somewhere close to where it should be and re-adjust the TPS setting. Then try it again after reading the whole tech article.
Old Jul 10, 2004 | 09:41 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
How long after start-up does it stay high like that? Does it go to something reasonable when you put it in gear?
Old Jul 10, 2004 | 10:39 PM
dwillms's Avatar
Car: 90 Integra
Engine: B18
When the car is cold, idles 1100/1000. Warm, drops maybe to 900. Cold idle in drive is 800-900, warm it gets to 600 or so.
The only reason I was trying to turn the idle screw was because the car wouldn't even run when I disconnected the IAC, so I was trying to see if that would make a difference in even getting it started.
If the screw is in far enough, it holds the throttle plates open a little bit, which would then bump up the TPS a little. I'm just not understanding exactly what I should do, the article makes perfect sense to me, except for the fact I am stuck about at Step 2 of the procedure .
-Dustin
Old Jul 10, 2004 | 10:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I believe that in one of the steps there that it mentions giving it a little gas if it is hard to start.
Old Jul 11, 2004 | 08:38 PM
gta ta's Avatar
Re: IAC won't adjust, need help
UPDATE: Tried to do the procedure again when the car was at normal operating temperature, still didn't work. Now, I reconnected my IAC, and my car now won't even start anymore. Issues... [/B][/QUOTE]
You have to give it some gas to start with the IAC motor all the way in. It will idle at like 400 so it will stall. It has to re-learn. You then go drive it. But if yours is like mine in 15 miles the high RPMs are back again.
I have been fighting a high idle in my 86 TA for years. Done everything. EGR, intake gasket, injectors, mat, computer and chip, tons of other things. vacuum is 22. I have come to the conclution it is an `86 T/A problem. Had GM machnnics look at it. Noone has an answer. I'LL pay anyone $100 if they can tell me why I have a high IDle. The computer is doing it but why.
Old Jul 11, 2004 | 11:43 PM
dwillms's Avatar
Car: 90 Integra
Engine: B18
Have you got into DIY Prom burning at all, or just got a replacement ECM and chip? I'm starting to get into it a little, I'm switching from the $32 to the $6E ARAP file that was used in 1989 cars, so I'd like to see if that makes any difference in my idle.
-Dustin
Old Jul 13, 2004 | 06:24 PM
gta ta's Avatar
-Dustin
NO I haven't. Vader had told me that early '86 Proms were defective so I went to the dealer and gave them $90 for a new with the part number Vader suggusted. I figured if I burnt my own chip I would mess something up and lean the engine out and burn a piston. I know it is the computer causeing this issue.
If it makes a differance let me know.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
greenyone
Sep 8, 2015 08:41 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
