View Poll Results: If you were going to use one of these WHich One would it be
VORTECH
33.33%
TRICK FLOW
66.67%
Voters: 9. You may not vote on this poll
Which One Would you use
Old Jul 11, 2004 | 11:44 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
ok I am looking at a couple intake elbow's to use to make the custom Air intake I am working on. I elbow will eventually have a tapped nut welded to it so I will have a good mounting solution for the Hitman EFI Nitrous Nozzel. I like the Vortech because it looks to be Beefier but not sure what that divider is for. The Trick Flow one is ok. I know most of the replies will say Make your own, which is a option but if you were going to get one which one would you get and why. Also these say that they mount to a LT1 Throttle Body, will they also mount to a TPI throttle body.
VORTECH
TRICK FLOW
Old Jul 12, 2004 | 12:09 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Mmmm... shiny, I like the shiny one.
Old Jul 12, 2004 | 01:25 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
The divider is more or less probably designed to act as an airfoil would..
Old Jul 12, 2004 | 02:54 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
and air foils really dont doo much.
I like shiny too.
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I would go with the Trickflow because it doesn't have the divider. I can't see how that is going to help any. If anything, I think it will hurt.
Old Jul 12, 2004 | 07:38 AM
gta_88_kicks's Avatar
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
The divider splits the airflow stream so that it doesn't get crammed up along the outside wall. Id go with the vortec.
Old Jul 12, 2004 | 08:56 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
If you want to introduce turbulance into the system to disrupt the viscous drag along the wall, dimple the wall, don't disrupt the flow in the middle.
Old Jul 12, 2004 | 10:18 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
well the Trick Flow One is probally the way I will go, I am not a big Fan Of shiny Objects,but it comes in Black Powder coated, Polished or Creamic Coated. I think the divider in the Vortech Would cause problems esspically if there is a space between the end of the divider and the Air Foil, plus it would probally interfere with a Nitrous Nozzel. Even though it is designed for a LT1 TB It will still fit a TPI throttle Body Correct?
Old Jul 12, 2004 | 11:49 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
are you using this on the late model serpatine setup? if so your elbow is going to have issues with your alternator......thier meant for the lt1's which dont have anything in the way right thier.....
buddy has the vortech elbow on his lt1....so i test fitted it on my 90 b2l iroc.....no go lol
Old Jul 12, 2004 | 12:31 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
nope The engine is a 85TPI No Serpatine
Please Excuse the engine bay in this pic, tha was shortly after I baught the car The stickers have since been removed and a very through detailing is Beautifucation is in progress
