engine stalling on idle help plz
Old Jul 13, 2004 | 05:09 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
since i got the car i've been having a problem with what i believe is the mass air flow sensor. i ran a test through my computer, and that is the code that keeps comming up. what happens is, i'll turn on the car, and sometimes it will just stall. or it will start to stall, idle at about 200 rpm for a while, then shoot up to 2000 rpm, then go down to 1000, and eventually even out. the problem is not consistant. it happens randomly, but the car rarely stalls while i am driving it. is a mass air flow sensor expensive? if so, how can i fix mine?? please help, the problem is not horrible, but gets annoying... thanks!!
Old Jul 13, 2004 | 05:33 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: engine stalling on idle help plz
You could have a major vaccum leak. Check for those first. Also could be your IAC, TPS and or your MAF. Not all aftermarket MAF's work well in our cars. Do a search to find out which ones work best. I wouldnt change the MAF until I was sure thats what the problem is.
Old Jul 13, 2004 | 08:11 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Maf
If you car was running fine prior to you getting the maf SES code.
Start your car and let it idle.
get a screw driver and knock on the sensor lightly if the car fumbles simultaineously when you knock on it , it is bad I bought one not too long ago and it was 140 bucks.
Old Jul 14, 2004 | 04:33 PM
bigchief's Avatar
yah see that sux... also my freggin light motors are going so i need new ones.... they asked 232 each at the dealership haha as IF!
Old Jul 17, 2004 | 11:21 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
could it be his EGR vavle going bad?
Old Jul 18, 2004 | 01:23 AM
bigchief's Avatar
what is that kind sir
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
backtothe80s
Sep 5, 2015 12:39 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
