Throttle Body Size
Old Jul 14, 2004 | 04:54 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
Throttle Body Size
I am the original owner of a 1989 GTA with a 5 liter TPI engine with a 5 speed manual transmission. A year ago I installed a new 5 liter long block from GM and had a Comp Cam and Heddman Hedders installed. The catalytic converters are gone with a 3" exhaust pipe emptying into a Walker super turbo muffler. A Bosch mass airfow sensor and K&N airfilter have been installed. The stock twin 48 mm throttle body is still in place and the plenem has not been ported and the two humps have not been ground down. My questions are: 1) with such a set up would I benefit from a twin 52 mm or 58 mm throttle body and which one both BBK and Holley make these; and 2) would I necessarily need to upgrade my stock 19lb/hr fuel injectors with a bigger throttle body. Once I make this throttle body decision I will complete the engine with a modified chip. I have received mixed opinions on whether a larger throttle body is required for my engine set up. I would appreciate some opinions and people's experience on this subject. Thanks.
Old Jul 14, 2004 | 06:54 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
In your case I would stick with the 48mm throttle body. With your 5.0 liter engine the 48 mm will flow enough for all your needs.
Old Jul 14, 2004 | 07:40 PM
OMINOUS_87's Avatar
I have a stock 48mmTB.
383 motor, check sig
Old Jul 14, 2004 | 11:05 PM
rsn932's Avatar
this has been discussed many times
try using "search"
and no you dont need a bigger TB
Old Jul 15, 2004 | 01:10 AM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Hello BC GTA your factory 48 Tb is plenty fine but what you need to do is get a sharp long object or screw driver and scribe the inside of your plenum on the outer inside edges of the throttle body blades.
Buy a upper intake gasket set.
remove your plenum
and port the front of your plenum to match the stock intake side.
When you get to the rest of the holes open them all as wide as you can making the edges smooth is probably more important than making them wide . "Wider is better"
You can also remove the screens from bothe side of your MAF sensor and possible hack saw off the aluminum fins inside if you have the patience.
you can also get 4 inch flexible intake tubing from the auto parts and some black electrical tape and run you a cold air tube from your air filter housing to the under side of your fender.
Old Jul 16, 2004 | 05:29 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Throttel Body Size
Thanks everyone for your input. I have decided not to increase the size of my throttle body.
Old Jul 16, 2004 | 06:26 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Wow, someone who punctuates, and spells correctly!!!!
Welcome to the boards
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
