tpi running rich??
Old Jul 18, 2004 | 11:26 AM
xeroxed's Avatar
tpi running rich??
im getting a 87 gta with tpi its running rich and stumbles on idle and quits running sometimes when the ses light comes on. i think its possibly the egr valve vacume lines not hooked up or a bad egr or maybe the selonoid. i was wondering if anyone else has had this problem. the people who owned it changed almost every fuel related sensor they could think of but its still doing the same thing. it also has a new maf sensor. im getting the car cheap so hopefully no one says stay away from it and by cheap i mean under $1000 and it has no rust.
Old Jul 18, 2004 | 11:52 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Pull the codes. Ask if the CTS and O2 was changed. How many miles? More info please.
Old Jul 22, 2004 | 11:55 AM
xeroxed's Avatar
i just got a chance to start messing with the car. it has 137k on it. it almost sounds like the timing is off because it pops every now and then. they changed the fuel pressure sensor thinking that was the problem. the egr vacume lines werent hooked up so i hooked them into wherever i could and i didnt see an egr solenoid. it seemed to smoothe out a bit after hooking up the egr vacume lines but im still getting a pop that sounds like timing. i know the ecm controlls the timing but could the dist. be turned far enough so that it throws the car out of timing and make it run like crap. i only have $400 into this car so itll be worth it to fix it.
Old Jul 22, 2004 | 01:02 PM
xeroxed's Avatar
i think i may have found the problem. i unplugged the throttle position sensor and the car smoothed right out just the ses light stayed on which is normal i guess. it quit popping threw the exaust when it was revved up.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
