Why is my car running ****ty?
Old Jul 18, 2004 | 07:00 PM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
I dont know why but i just swaped from a LT1 intake to a HSR and then i changed the MAF sensor and i changed the MAT sensor and O2 sensor, And TPS sensor, then after changing all that i went to run it and now it wants to like buck and surge at any RPM any gear but you have to hold it at any certain rpm and itll do it. im not sure i checked my fuel pressure idling and its at 43(AFPR), i also checked my codes and its throwing a 42 code, so i replaced the ESC module and i replaced the ignition module, the plugs and wires are new cap and rotor are new, i checked the plugs and they look brand new every time i run them so im figuring its running lean, it also takes a little bit to start, i know the EST wire is connected and the car isnt in "safe" mode, can anyone help me out on what my problem is? i really need help! anything would be appreciated!
Old Jul 19, 2004 | 01:07 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Why is my car running ****ty?
What happens when you apply the brakes? If it seems to cause an idle problem then its a vaccum leak. Did you set the timing when you put dist back in? Sometimes the car will run that way if the dist was put in 180* off. Hmmm....I didnt have this problem when I installed my HSR. It sounds like a timing or fuel issue. Did you set the TPS in the right spot and check it for .54? Did you disconnect the tan/black wire (ECM?) connector before timing the car? Hope these help.
Old Jul 19, 2004 | 07:51 AM
Car: 85 Camaro Z-28
Engine: 6.6
Re: Re: Why is my car running ****ty?
nothing happens when i apply the brakes but it will idle down then up then normal when i push the clutch in. i set the timing at 6* base timing with the EST disconnected, i originally had it in the 180* off but i got it right now. and im not sure what you mean check my TPS for .54? thanks for trying to help me, right now i need it.
Old Jul 19, 2004 | 05:33 PM
Re: Re: Re: Why is my car running ****ty?
When you take the tps sensor off it has to be checked or reset. The proper reading you should get for the car is .54. There is a tech article here on how to adjust some of the sensors including TPS. Also the IAC valve could be off but that only involves (controls) idle to 2000rpms.
Old Jul 19, 2004 | 05:39 PM
Re: Re: Re: Re: Why is my car running ****ty?
Old Jul 19, 2004 | 10:42 PM
Car: 85 Camaro Z-28
Engine: 6.6
When you say "proper reading" should be .54 do you mean with a volt meter or whatever that tool is to test voltage going to or from it? im not exactly sure but tomorrow if i have to ill buy one or borrow one and see what its at, if anyone has the link to checking that id greatly appreciate it, but about my bucking and surging problem, i think some of the wires are bad because i had the idle up and i removed one at a time and it stopped popping so either a bag plug or bad wire, so i kinda think i figured that one out plus i reset the codes after i adjusted the fuel pressure and the code 42 is gone, and now its just the code 23 for the MAT or TPS(which its the TPS) error. so im getting there i just really need to know how to adjust or test the TPS
Old Jul 20, 2004 | 12:41 AM
Re: Re: Re: Re: Re: Why is my car running ****ty?
Here you go my friend...
http://www.iroczone.com/techarttpsadj.html
Old Jul 20, 2004 | 07:47 AM
Car: 85 Camaro Z-28
Engine: 6.6
wow that helps alot man! thank you very much!:yourock: lol
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
