Brown smoke?!?
Old Jul 27, 2004 | 01:57 PM
WinnipegGTA's Avatar
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Brown smoke?!?
What does this indicate. It a brown color, doesnt look like oil, The car has been sitting for 10 months with a nearly full tank of gas w/ Stabilizer in it. Any idea of what to look for. Also my fans rattle for some stupid reason, where are all the bolts to tighten it up. I know its them cause as soon as i press on it firmly rattaling stops. Please help.:hail:
Old Jul 27, 2004 | 03:05 PM
subliminal's Avatar
I dont know about the brown smoke, but the fan bolts i do. Near the top of the radiator there is 2 bolts for each fan. then on the bottom of the radiator there is 2 more bolts for each fan.
Old Jul 27, 2004 | 10:08 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If the car has been sitting a while, it is a definite possibility that the puff of brown you see is eveidence of iron oxide build ups.
Old Jul 28, 2004 | 12:56 PM
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Iron Oxide aka rust? Will it blowout with use? or should i run something through the fuel system?
Old Jul 28, 2004 | 03:33 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
fresh gas and driving it around wouldn't hurt.
Old Jul 30, 2004 | 02:21 PM
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
With a lil driving brown smoke has disappeared
Old Aug 1, 2004 | 11:21 AM
tommygun's Avatar
Car: 1992 Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 3.23 Posi
That's why whenever you let a car sit for that long, you should either start it once a month, or coat the cylinders by spraying fogging oil through the intake until the engine quits. I have to do this to the 454 in my boat every fall when I winterize it. Otherwise the engine oil will run down, and rust will form, eventually requiring a rebuild. The rust can score the cylinder walls and damage piston rings if it gets bad enough.
db057
Apr 28, 2019 07:45 AM
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
tattmann
Sep 27, 2015 05:20 PM
