MAF experts needed.
Old Jul 28, 2004 | 03:20 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
MAF experts needed.
I recently started to get code 33 so i tried to troubleshoot after doing my homework.
The only thing that does not check out is the voltage at the dark green wire.
With ignition on, MAF connection plugged in i get 2.5v at that wire and same at the b12 terminal at the ECM.
Then when i unplug the MAF, i get 5.0v at that wire and same at b12? WTF.
What would that indicate??
Old Jul 28, 2004 | 03:30 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i had the same problem. all the relays and ecm were fine. the maf itself was bad.
the filiment wire was glowing red on and off.
Old Jul 28, 2004 | 11:11 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you done your checks using the code 33 trouble shooting chart that has been posted on the board numerous times? Just a thought. BTW, that dark green wire goes to pin "B12" on the ECM and is the 5 volt MAF signal.
Old Jul 29, 2004 | 12:02 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I haven't found the chart yet. The b12 is reading 2.5v with MAF connection in and 5v when unplagged?? WTF.
Old Jul 29, 2004 | 12:12 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I have it posted in this link danielek, you will to scroll down several posts in it but it's there.
https://www.thirdgen.org/techbb2/sho...ght=maf+sensor
Old Aug 9, 2004 | 12:46 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Update:
I tried troubleshooting using Trickster's chart and all pointed out to a faulty MAF..
I ended up buying a used MAF and plugged it in.. Before i started the car i did this:
- ignition on
- MAF connection plugged in
I then checked the voltage at the B12 terminal to see if it is what it should be and it is STILL showing 2.5V.
Car started good, no codes, run for 2 hours, no codes.
My question is should i be getting 5v at the b12 terminal when MAF connection is plugged in??
I am getting 5v when i unplug the MAF connection..
Could somebody check that on their car. I don't want to worry anymore...
Old Aug 9, 2004 | 03:39 PM
NYIROC's Avatar
Car: 87IROC
Transmission: MAD DOG 700R4 w/3:73 posirear
This is another question about the MAF. I've noticed my car produces much more power when I unplug it - WTF? It dosn't idle as good but when I mash the throttle when its unplug I get two nice black stripes behind me. When plugged in I get a hug hesitation.
Regards,
G
Old Aug 9, 2004 | 05:01 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Are you running a modified prom??
In my case is the other way around. When unplugged it runs OK, when plugged in it runs like a charm...
Old Aug 10, 2004 | 09:36 AM
NYIROC's Avatar
Car: 87IROC
The prom is a Hypertech thermomaster chip.
Old Aug 10, 2004 | 07:29 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
That is your problem right there.. It tells you how good those aftermarket chips are...
Can somebody please test the voltage at the
- b12 terminal with
- key On and
- MAF connection plugged in???
What should the voltage be??
I did more testing today with a scanner plugged in and it the showing WITH KEY ON,
- maf reading of 23 gps which should equal to 1.5v (based on the maf table). When i ckeck the voltage at the b12 I get 2.5 volts and not 1.5v?
When i start the car the signal wire voltage corresponds with the MAF table readings.
racereese
Oct 3, 2015 03:46 PM
djmarch
Oct 2, 2015 10:41 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
bschmale66853
Sep 30, 2015 08:11 PM
