valve lash too tight?
Old Aug 6, 2004 | 08:36 AM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
what are the downsides to having the valve lash/rockers set too tight? what will i notice if anything and what problems could i be facing? the engine runs now and seems to run fine except for a low idle and im just making sure i shouldnt be nervous about my tightening skills (cuz they def arent loose)...ok thanks a lot
Old Aug 6, 2004 | 08:51 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
If you havent touched your valves then thats not the problem. I dont see anything in your sig about rockers or anything, But if you have I would go with adjusting them with the motor running. Low idle can be a number of things. Whats wrong with low idle? Whats happening?
Old Aug 6, 2004 | 10:36 AM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
yeah sorry, i took the rockers off and did a cam swap...so i set them with the motor off...im not necessarily having any problems, im just trying to determine what to look for if they are too tight cuz i know they arent too loose and i dont trust myself...
it idles at like 750 and then drops to 500 and stumbles but after it warms up in drive or reverse it drops low enough to die...i havent checked the timing yet so im thinkin that has somethin to do with it...
Old Aug 6, 2004 | 11:28 AM
greenfrogg's Avatar
Car: 89 FORMULA355 80 TURBO TA 355
Engine: 355 tuneport 355 chev CARB
Transmission: 700 350
theres all kinds of prob's it could do like pulling shafts 4 the rockers loose . i know of a lt1 haveing the same prob. you will notice a change in power also tight valves will hold you backin rpms .its almost isay almost better to be a little loose rather than tight. do a search on the subject you will find how to do it better. goood luck
Old Aug 6, 2004 | 11:46 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Adjust them with the motor hot and with it running. Then you know you have done it correctly
Old Aug 6, 2004 | 11:58 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
There is no "correct" way of setting the valve lash. There is, however, the personally preferred way. I have set the lash with both the engine on and off. The engine on is quicker. Perhaps "more precise." There is definitly less of a science to it. But I have also set it with the engine off. I like this method after a fresh rebuild. Since it requires 2 full rotations of the engine, it gives time to check clearances and whatnot as well.
If you suspect a poor valve lash setting, you can either do a compression test or reset them. For a low and somewhat searching idle, bad valve lash setting doesn't jump out at me as one of the causes. When you did the cam swap, what EXACTLY did you end up replacing/removing?
Old Aug 6, 2004 | 12:25 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
ok so if i do them again with the engine running i just tighten until they stop making noise and then a half turn? or is there a better way?
i removed everything necessary to change the cam...smog, intake, wiring harness, vaccum stuff, a/c, alternator, water pump, crank pulley, harmonic balancer, valve covers, rockers, pushrods, lifters, cam, radiator, u name it...im not too worried about the idle tho...
Old Aug 6, 2004 | 12:53 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Back off the nut till it ticks (You'll know) then slowely tighten till it stops and then go 1/2 turn. Go slow when you do it. You'll hear the engine bog when your turning it. Once turned the idle will even back out.
gta892000
Aug 11, 2019 11:16 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
dimented24x7
Sep 6, 2015 03:51 PM
