What is this piece!?
So today I went to change the fan switch, since its inbetween the 6 and 8 cylinders like I was told. I have a replacment low temp fan switch and all. When I pulled this (see photo) from the bottom of the block on the passanger side, it looks nothing like my fan switch, someone please tell me what this is! If this is not the fan switch, where can it be found. I have an 86z28 but someone has change the engine before. Its a 305 tpi, I assume the same engine as stock. Help please!
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
the fan switch is in the right side(pass) head between cylinders number 6 & 8 just under the exhaust manifold.
Car: 87' IROC
They are correct, your picture is of the knock sensor. The fan switch like already said is above the knock sensor under the exhaust manifold.
How come when I was under there I could not see the fan switch, and I did look right above the knock sensor.So, just take off the exhaust manifold and I will be able to get to the fan switch??
if you look at the left head(drivers side) between cylinders 1 & 3 you should see the sending unit for your temp gage, now imagine if you were to take the left head & put in on the right side, that is were the fan switch is on the right head. 1 of the past owners may have removed the switch, so there maybe a screw in plug were the switch is suppose to be at.
it's pretty much dead center between the #6 & #8 spark plugs & almost dead on the same level with them
you shouldn't need to pull the exhaust manifold to get at it.
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
No, the fan switch is between cyls 6and 8. The knock sensor goes into the side of the block, a couple inches above the oil pan.
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
Originally posted by Z28Fbody87
There was a threaded plug in place of where the fan switch goes. HOw could the fan have ever came on if there is NO fan switch at all? Ive seen it run before...
I don't like that however, since there are times when the fan needs to stay on after the car is shut off. So that's on the fix list.
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
'86 LB9 motor did not have a thermostatic fan switch as only a single fan was the factory setup and it was controlled by the ECM only. In '87 the dual fan setup came into existence and the thermostatic switch to control operation of the secondary fan was placed in the passenger head.
Car: 87' IROC
Z28, do you have dual fans? If not, you don't need a fan switch.
I have a single fan setup.. I was misinformed about the fan switch. I am really lost, lol I just want my fan to work!!! I checked the fan it does have power, I replaced the relay and thermo (180 degree). It still doesnt work!
