Those with 1.6 RR's and Centerbolt heads, come inside please.
Old Aug 21, 2004 | 08:27 PM
vwdave's Avatar
I noticed some people are running the Comp Pro-Magnums Roller rockers. What did you need to do to get them in there?
Old Aug 21, 2004 | 08:43 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
i swapped vette heads on with my roller rockers, i dont have the rockers you mentioned , but i am runnin steel valve covers off a 93 buick roadmaster LOL.
Old Aug 21, 2004 | 09:04 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Don't know if this will help but I'm running the Trickflow 23 degree heads with Crane 1.6 roller rockers. I'm also using the stock valve covers. I also have a ZZ9 style cam (clone). Allen
Old Aug 22, 2004 | 01:18 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
i'm running crane gold 1.6 rr's on ported l98 heads and stock centerbolt valve covers. im pretty sure that you cant put pro magnum rr's in centerbolt valve covers. someone correct me if im wrong...
Old Aug 22, 2004 | 01:43 AM
Z69's Avatar
Z69
I'm running Some narrow body 1.5's, but I was told I'd need double gaskets to get them to clear. Not true. From what I can tell, as long as your cam does not have enough lift to push the P rod end up into the cover. Which would be huge with 1.6's I'd think. 1.6's move the push rod towards the stud, so that end doesn't actually go any higher I think.
So you only have to worry about trunion width. That's what is closest to the tubes for the hold do bolts. Oh and big retainers.... But my 1.460 retainers clear. I just put white grease on the rocker tips and left the gasket off. Put the covers on and turned the engine by hand to check for clearance. The grease will let you know if your close.
I think all you really have to worry about is the trunion. But I have vortecs at the moment. Some heads have a taller cover rail than others.
Old Aug 22, 2004 | 04:33 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I assume you're wondering how to make them work with stock center bolt valve covers....
Here ya go!- http://www.hotss.com/Members/scott_vaca/pro-mag.htm
Old Aug 23, 2004 | 09:00 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have the pro mags. Just had to take out the baffels.
Old Aug 23, 2004 | 04:17 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i bought some tall polished aluminum ones off ebay for like $70. nice pieces
Old Aug 23, 2004 | 06:58 PM
vwdave's Avatar
Pics?
Old Aug 23, 2004 | 09:04 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
not the best
Old Aug 23, 2004 | 09:15 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Originally posted by KagA152
not the best
i bought a set of pro-form high rise center bolt valve covers and aluminum 1.6 proform roller rockers. i think the valve covers were $120.00 and the rockers were $180.00 i dont remember, anyway they fit perfectly. Also what kind of wire looms do u guys recommend for high rise center bolt valve covers?
midge54
Dec 27, 2019 04:14 PM
MoJoe
Sep 24, 2015 09:12 PM
g.l.mos
Aug 22, 2015 12:02 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
