Can a stock baseplate be ported to match the diameter of a set of HiFlow runners?
Old Aug 30, 2004 | 12:49 PM
blackedout85's Avatar
Car: 85 Corvette
Engine: Tpi 350
I know the Plenum can be port matched but what about the stock intake?
Old Aug 30, 2004 | 03:05 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
if you open up the ports in the base to match a large tube runner, there wont be much surface left for the gasket to seal. and the only way that i know of to get stock base to match the flow of some big runners would be to siamese it. way too many people have put on large runners with a stock port matched or unported base and have either slowed down or saw no performance increase. i am sure others have an opinion about this but i would not advise running the stock base with big runners, but if you have to run the stock base at least siamese it.
Old Aug 30, 2004 | 05:17 PM
BadSS's Avatar
Re: Can a stock baseplate be ported to match the diameter of a set of HiFlow runners?
Yes they can,, done plenty without any problems sealing.
Old Aug 31, 2004 | 09:56 PM
formulaman's Avatar
My buddy did his, but it is really super thin around the tops of the runner entrys.
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89-S-dime
Aug 12, 2015 11:57 AM
mx127
Aug 10, 2015 08:13 AM
