sweet lokar throttle brackets!!!
Old Sep 26, 2004 | 11:09 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
ok first off whats a kickdown??? i have cruise on my car and when i look at the stock throttle bracket i only see two cables attached. but i like these and dont know which one to purchase....Lokar TPI throttle Brackets there is the one stud, two stud and three stud.
also i want to get the lokar cables too, which ones would i need? i want both of the cables (the one from the pedal and the one that runs to the vacuum thing) replaced heres the link to thosehere
thanks guys
Old Sep 27, 2004 | 12:34 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
ttt one, two or three stud and what type cables?
Old Sep 27, 2004 | 01:02 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You want the three stud because you have cruise control and probably want to keep it. The "stud" they are meaning is how many holes there are for cables. Kickdown cable is for an automatic transmission.
Old Sep 27, 2004 | 01:04 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Just go ahead and get the "tuned port" style cables. Looks nice and they work good.
Old Sep 27, 2004 | 01:39 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
i was thinking the three stud but ive only got two cables on the bracket now. and i have a manual tranny. one cable is my actual throttle cable and the other one runs around to the front of the car to a vacuum thing it looks like. and i planned to get the tuned port cable for the throttle but for the other cable (the one that runs to the front) i didnt know which cable would work
Old Sep 28, 2004 | 12:00 PM
Tibo's Avatar
Car: 1991 Z28 Vert
You have to get the three hole bracket if you want cruise. The cable that goes to your "Vaccum thingy" is your cruise control. When operated it will collect enough vaccum to hold the cable hence the throtle in place.
Old Sep 28, 2004 | 12:37 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I'm thinking you need the two hole design. One for your throttle and one for your cruise control, which is the one in front that goes to the vac tank. You don't have a kickdown cable if you have a manual tranny.
Old Sep 28, 2004 | 02:57 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
wow you learn something new everyday....always wondered what that was. but since i dont have an auto tranny does anyone know for sure if i need the 3 stud or 2 stud design?
and as far as the cruise cable which one would fit?
Old Sep 28, 2004 | 03:07 PM
Car: 89 IROC-Z
Engine: 383
I would suggest calling them to find out exactly what they mean by studs. Could be the number of mounting bolts used since a lot of guys retrofit TPI's into older cars there may be some that use only 1 or 2 bolts, but I don't really see how.
Old Sep 28, 2004 | 03:13 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
yea im probably going to call them however the awesome techs really dont know anything except whats obn their screen. in the catalog it does say the one stud is for the throttle, two studs for the throttle and kickdown, and three studs for the throttle, kickdown, and cruise. any ideas
Old Sep 28, 2004 | 03:41 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
You need to studs (holes) for your 2 cables.
Old Sep 28, 2004 | 09:26 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
two studs it is, hope it work out okay. now no to the cables i think i need the tuned port polished cabnles for the throttle but as far as my cruise (i want it to match) i dont know what cable i would need to use any help?
Old Sep 28, 2004 | 11:46 PM
Tibo's Avatar
Car: 1991 Z28 Vert
NO! I said in my above post that you need the three stud. It says it specifically in the ad that
"...a single stud for throttle only; double stud for throttle and kickdown
and triple stud for a throttle, kickdown and cruise control cable.
Did everybody else read the ad? "Stud" is meaning "hole for the __ cable." Not the number of bolts. Retrofitting TPI has nothing to do with a throttle bracket. You use three bolt holes unless you want your bracket to wander. They do not make different throttle bolt patterns.
Once agian, you need their THREE STUD design unless they are going to make you a different bracket. This is a simple question that does not require arguing or lots of thought.
Old Sep 28, 2004 | 11:51 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
i know it means the holes for the cables not bolts but i guess i am not getting it, no need to yell (and thanks for the help BTW). but i dont have a kickdown so wouldnt the 2 stud work????? if not i guess i will just have an extra place for a cable with no cable?
Old Sep 29, 2004 | 12:08 AM
Tibo's Avatar
Car: 1991 Z28 Vert
OK, triple stud is the only design that Jegs sells that incorporates throttle and cruise control. I agree with you that it would be nice if they sold one that was only cruise and throttle, but they don't. The two stud could work if you went to all of the trouble of making or buying a custom cable to work with it. It is mainly about the angle and length from the bracket to the throttle.
Old Sep 29, 2004 | 07:46 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
My old 2 Stud.
Throttle Cable and Kickdown.
Old Sep 29, 2004 | 07:49 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
ok well then i need a three stud i just thought i could subsitute the kickdown for the cruise (didnt know there was a difference in the actual cables)
does anyone have a pic of the three stud mounted on a car???
thanx tibo!!!
Old Oct 27, 2004 | 02:15 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Here's a pic of my 3 stud mounted on my Stealth Ram with the Lokar TPI cable as well:
I really like how the Lokar stuff works, except that the mounting bolts for the bracket were too long and I bottomed one out and stripped out the threads in my Stealth Ram, but that's another story I too am a bit curious as to how I'm going to set up my cruise control cable (in fact I found this post while searching for information on it). I've got a Dakota Digital cruise control package that I'm going to be installing and it just has a standard cable hooked to the electric servo for the cruise. First off this cable won't match my throttle cable and look pretty (not a HUGE issue, just an annoyance) and secondly I have no idea how I'll attach this cable to the Lokar bracket. I looked through Lokar's website and didn't find any cruise control cable kits or anything like that so I'm kind of stumped right now, although I haven't even started installing the cruise yet. Anyway, if anyone has any experience with using these Lokar brackets and keeping cruise control functional I'd be very interested to hear! Good luck with the bracketing and cables CamarosRUS!!
-Paul
Old Oct 27, 2004 | 03:13 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
yea those do look real sweet. im still searching to figure out how i can hook up the cruise with a cable too because i wont do it unless i can do it all. but thats an afterthought anyway, i need to finish the engine!
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
TheTraut88
Sep 11, 2015 05:16 AM
Randomtask2
Sep 7, 2015 05:06 PM
Kenwood
Sep 4, 2015 05:50 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
