New ET again..
Old Sep 27, 2004 | 04:17 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
New ET again..
Traction is a great thing. With Nitto's propelling me to 1.7 and 1.8 60's consistently I managed a best of 12.89. Consistently I went 12.9's. Next year I will have a better computer tune and I will finally use the Nitrous!!
Old Sep 27, 2004 | 04:44 PM
91blackz's Avatar
Car: 91z
Engine: 5.7 TPI
Awesome time, i cant wait till i get there. And yes the nitto's are an awesome tire.
Old Oct 1, 2004 | 06:30 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
What was the 60' before the Nitto's?
Old Oct 1, 2004 | 07:01 PM
nick418's Avatar
Engine: L98, Hemi 6.2
great times
Old Oct 1, 2004 | 09:18 PM
speed88's Avatar
Engine: 383
2.2's to 2.4's
Old Oct 2, 2004 | 08:21 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Good going. That's an amazing difference.
Old Oct 2, 2004 | 09:19 AM
TragicPark's Avatar
Engine: 5.7L V8 TPI
Hey I'm new here and I was wondering what you've done to your car Speed88, if you care to share? TIA
Nice numbers by they way !!!!
Old Oct 2, 2004 | 09:53 AM
turbotater's Avatar
congrats on the 12's club
which means the 11's club is a spray away
what torque converter do you have
mike
Old Oct 2, 2004 | 12:20 PM
speed88's Avatar
Engine: 383
Thanks for the comments guys.
TragicPark: I have pretty much gone through my car. All the suspension, such as shocks, springs, LCA's, Panhard bar, etc, etc. I have had my 700R4 rebuilt with alot of go fast stuff, pretty much bullit proofed it. And my old TPI'ed 350 has been replaced with a Minirammed 383.
I was hoping for better times, but I knew my choice in heads, cam, and the fact I'm still running the stock 9 bolt 3:27 rearend was going to be a "bottleneck" in my combo. It was just more of one than I had antisipated!
turbotater: Right now I have a TCI 3000. But in the fall of 2005 I will be going with a much larger head and cam package, and I will be topping it off with a 3500 stall.
Old Oct 2, 2004 | 11:46 PM
TragicPark's Avatar
Engine: 5.7L V8 TPI
Awesome setup!! I was hoping that you kept the 350 so I could get some ideas on what to do. Oh well, I'm in high school so I guess I shouldn't worry to much about all that. Anywho, again nice setup! Glad to see a 3rd gen put down so much power and run in the 12s.
Old Oct 3, 2004 | 10:02 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
What heads and cam do you have now?
Your only trapping at 105 w/ a minirammed 383? Sounds like you should be high 11's all motor w/ another 10mph.
Old Oct 3, 2004 | 10:17 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Originally posted by speed88
2.2's to 2.4's
2.4 to 1.7 with just a tire change?
DAYUM!
Old Oct 3, 2004 | 12:33 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
My Science Professor's TPId Vette went from losing traction on the 1-2 and 2-3 shifts to only spinning off the line with just a tire change.
Old Oct 3, 2004 | 01:44 PM
Dr G's Avatar
Speed88:- Was the difference in your 60'time that marked with just the Nitto's? Or where any of the other mod's listed did between those track times also.
Do you mind if I ask what tires you had on previously? Were they really old and hard? How much of a burnout do you give the Nitto's at the track?
Thanks, and well done on your times!!
Old Oct 3, 2004 | 04:33 PM
speed88's Avatar
Engine: 383
Free Bird: Unfortunately I only have a set of WP Torquer S/R heads. At the time of the my engine build-up, the budget was getting a little thin and I had those sitting on my work bench from a previous project, so I freshened them and ported them and on they went. But they still hold me back..big time!! My cam is the LT4 Hotcam, and this cam was used for the same reasons. Money, and I already had the cam from a previous project, so in it went. However, possibly this spring, but if not the fall of 2005 I will be getting a set of Dart 215cc aluminum heads and a Comp Cam, not sure on what grind yet?
Cadilac: Dayum is right!!!
Dr G: Yes. The only difference in the car from the weekend I ran street tires to the weekend I ran Nitto's was the Nitto's. NOTHING else was done to the car. The street tire I was running was a set of Goodyear Eagle GT II's. I dropped the psi in the Nitto's to 16, did a some good burnout's and dropped my 60's. And when I say good burnout's I mean I would stage the car in the burnout box and when smoke starting passing by my window I would move ahead!
Thanks for the comments guys. Any more questions feel free to ask.
Old Oct 11, 2004 | 06:50 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
OK, that makes more sense. The heads and cam swap is going to help you out a lot. I think you already know this.
on the cam, I'd shoot for something in the 230 and up range. I'm running a comp 306 lt1 cam in my 355 and love it. But that's a little small for a stroker w/ darts and a mini ram.
Old Oct 16, 2004 | 11:15 AM
brutalform's Avatar
good job! 11.70s on a 150 shot is gonna happen,(or quicker). roll bar time!
Old Oct 16, 2004 | 03:29 PM
speed88's Avatar
Engine: 383
EXCELLENT!! :rockon:
nicksL98
Apr 5, 2004 09:54 PM
Crisis
Mar 14, 2003 07:19 AM
KiLLJ0Y
Southern California Area
Mar 11, 2003 04:18 PM
KiLLJ0Y
Mar 6, 2003 09:16 PM
breathment
Mar 29, 2002 07:07 PM
