cold start problems(not cold sart injector)
Old Sep 28, 2004 | 07:43 PM
camaro_60181's Avatar
Car: 1986 Iroc z28
I've been having a hard time getting my 86 z28 to start in the morings... I have replaced the cold start injector, fuel filter, maf, cap, rotor, plugs and wires. I checked the fuel pressure and I'm getting about 36 psi at the rail. It will crank for 30 second then act like it is going to start then dies. It won't stay running unless I give it gas. After that its fine the rest of the day. any suggestions?
Old Sep 28, 2004 | 10:50 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Replace your fuel filter and if that's recent or if that doesn't fix it, buy a new fuel pump.. I too believe I have low fuel pressure, but I have yet to check it. I have a 255lph Walbro sitting here on my desk waiting to be dropped in
Old Sep 28, 2004 | 11:18 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
How about the Cold Start Switch and the Coolant Temperature Sensor?
Old Sep 28, 2004 | 11:30 PM
1320 Right Ln.'s Avatar
also might want to check that your motor isn't getting starved of air. the passages for the IAC stepper motor may be clogged up, the motor may not work at all, your set-screw for adjusting the closed position of the TB throttle plates may need to be turned in.
Old Sep 29, 2004 | 04:15 PM
Car: 1986 Iroc z28
where is this cold start switch? Is there a way to test it. I don't want to just throw money at the car in hopes that it might work.
Old Sep 29, 2004 | 04:18 PM
Car: 1986 Iroc z28
I don't think its getting starved for air. If anything its starving for fuel...I Just passed emmissions last week. Was less than half the limit for hc's
Old Sep 29, 2004 | 04:52 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here is a picture of the cold start switch and there is no way to test it. The cold start switch is the reddish colored connector on the left and the black colored one is the coolant temperature sensor.
Attached Thumbnails cold start problems(not cold sart injector)-front-intake.jpg
Old Sep 29, 2004 | 06:34 PM
Car: 1986 Iroc z28
thanks trickster....I guess I'll have to give that a try.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
