Which cylinder it is?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: Which cylinder it is?
Originally posted by DANIELEK
The one without the wire, which cylider should it go to??
1 or 8
1 or 8
Please note position of distributor cap mounting screws. Last edited by Trickster; Oct 4, 2004 at 10:45 PM.
Car: Red Rooster
Transmission: M5
1 or 8
1 or 8
What is trowing me out is that line in the middle of the distributor.. The way it is positioned when i look at that line from the front looks like 1 pm .
But if that line is the middle then all of the wires were not connected properly..
If i were to judge it by the two fastners at the bottom it still appears that that line is in the 12 pm position.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
When you have the distributor set in there. Have the connectors at the rear pointing straight towards the firewall and the #1 cylinder post on the cap will be at the 5 o'clock position.
Car: Red Rooster
Transmission: M5
If i assume that that line/connectors should be 12 oclock them in the above picture that one connector without the wire should be cylinder #1, right??
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
AFAIK, the actual location of each plug wire on the cap isn't as important as their relation to each other. AKA - If the engine is at #1 TDC firing, and the rotor is pointed to terminal "a", where "a" is no particular terminal, then as long as terminal "a" is wired to #1 cylinder, and the rest of the wires follow around in order, thats all that really matters.
I think that the picture Trickster posted more or less just shows the firing order around the cap and not really where each plug wire needs to be.
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Steck....what you say is true from a workability standpoint. However, GM established LONG ago that there needed to be a common reference for where #1 goes, so that you don't have to pull up the cap and put #1 on TDC compression every time you need to change your plug wires.
Typically, the tower nearest the #1 cylinder is the #1 tower. Viewed from the front of the engine, it's the terminal nearest the 5 o'clock position.
Car: Red Rooster
Transmission: M5
I took the car back to GM dealer and told them that the car seems like it has no guts.
I told him to recheck the timing, etc,, The service manager then told me that when him mechanic tried to adjust the base timing he unpluged the wrong wire. So i think the problem lies there but i have to wait till tomorrow to really find out.
