camaro airbox on a firebird?
Old Oct 21, 2004 | 05:44 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Hey im converting from carb. to tpi on my trans am. I just wanted to know if i could use a camaro airbox on my T/A? If i do get one do i have to make cut outs in the area between the radiator and the nose? I dont like the factory air ducting for the firebird and i dont want to move my evap canister to the other side along with my battery. I have a MAF system so i cant just bolt the filter to the throttle body like a SD system, and i cant afford a ram air hood to fit a ram air box right now. Any suggestions? Thanks,
Old Oct 21, 2004 | 10:19 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
sorry dude but i dont think it is possible to get a camaro air box to fit a 'bird without some major cutting to the radiatior support. the bird has a much lower hood line and the nose is supported by a big metal pan that is welded to the radiator support. it woudl be way easier and much less of a hack job if you just used some 3 inch ducting and made your own cold air intake. many on here have done it, just do a search.
Old Oct 22, 2004 | 11:35 AM
Guest
Guest
Posts: n/a
Wont work.
If you dont like the factory setup, create some sort of CAI with 3" pipe.
Old Oct 22, 2004 | 12:44 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Originally posted by madmax
Wont work.
Exactly what I am going to do. Going to use PVC pipe to get it setup, and either just paint the PVC or cut and weld a metal setup instead, but only downside there is heat soak...
Old Oct 22, 2004 | 09:12 PM
vortec77's Avatar
Car: 86 T/A
Ok thanks for the responses guys. Do you think i can get away with leaving the canister and battery alone or do i have to move them?
Old Oct 23, 2004 | 01:42 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
I am leaving both of mine alone. I am just running the PVC the same routing as the stocker, just bending it at the end down w/ a K&N cone filter on the end...
Old Oct 23, 2004 | 11:22 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I set one up in my car just the other day. Removed the pan that held the old stock airbox and evap canister and ran a 3.5" pipe to a 4" x 9" K&N cone filter and cut a hole right where the old box was to fit it down to suck in cold air. I forced the evap canister in the corner held in by the intake tubing. If I can get some better pics, I will post them.
Oh, and the K&N sounds sweet
Old Oct 23, 2004 | 03:46 PM
vortec77's Avatar
Car: 86 T/A
Sounds cool!! When you get those pics id like to see them.
Old Oct 23, 2004 | 03:50 PM
Car: 1997 Corvette
Here's a pic from the front looking down to the filter.
Old Oct 23, 2004 | 03:51 PM
Car: 1997 Corvette
Here's to kinda show what I did with the evap canister a little better.
Old Oct 23, 2004 | 03:54 PM
Car: 1997 Corvette
This shows how much of it is below the car sucking in cold air.
Using this setup, my manifold air temps dropped 25-30*F from 122-124*F to 96*F. Those first temps were even with a slightly modified stock airbox to allow in some cool air. I haven't checked the temps when moving, but I'm assuming its going to be even lower when driving on highway, etc.
The intake is stock from the TB to the MAF, and then I have the rubber hose connecting the PVC pipe section to the MAF. I will eventually make this look better once I switch to SD-MAP and the LT1 intake.
Old Oct 23, 2004 | 03:55 PM
Car: 1997 Corvette
Oops forgot pic and can't delete post to re-post it
Old Oct 23, 2004 | 04:00 PM
vortec77's Avatar
Car: 86 T/A
Cool, Im trying to do the same thing but without having to swap my battery and evap. canister. Maybe have the filter run to a little bit before the Battery, any suggetstions?
Old Oct 23, 2004 | 04:22 PM
Car: 1997 Corvette
I don't know your setup, my battery is on the driver's side, stock. My airbox and evap caniseter were on the pass. side.
Old Oct 24, 2004 | 09:58 AM
vortec77's Avatar
Car: 86 T/A
Ok sorry, My Trans am originally came with a 305 Carburated and i am now converting to tpi so my battery is on the pass. side and my evap. can. is on the drivers side and im trying to get away with not having to swap them when i get ready to hook up the air ducting
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Linson
Aug 21, 2015 02:12 PM
antares57
Aug 6, 2015 07:47 AM
