Engine light for what?
Old Nov 1, 2004 | 02:34 PM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
code 12......
Im getting my check engine light and for some reason when i check the codes it only tells me 12, which is obvious, the car will run good once its up to temp and really doesnt like to stay running very well, its on the virg of stalling and then does. but when its up to temp its fine. and i have a new CTS on it so i doubt its that. but i dont even get a code, i was getting code 23 which was mat and i put a 2200omh resistor in there and the code went away. but im still getting that light. anyone have any ideas? when i check the codes when its running, i get a fast consistant flashing of the light.
Old Nov 1, 2004 | 10:33 PM
Car: 85 Camaro Z-28
Engine: 6.6
i need help soon before i send my chip away to be redone(not for this reason)
Old Nov 1, 2004 | 10:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you tried putting a diagnostic scan tool on the car to see what it is doing or are you using the shade tree mechanics specialized diagnostic scan tool that in its original form is designed to hold papers together.
Old Nov 1, 2004 | 11:03 PM
Car: 85 Camaro Z-28
Engine: 6.6
lol man you know im not that high tech(paper clip), im using some old harness wire stripped at each end. lol i dont think that tool would work unless it only uses those 2 pins, since i converted it to TPI i have the wires that go there but i had 2 orange wires that im not sure are neccesary but i have them there along with a red wire to the ALDL and there just not put in the connector. so if it just uses the 2 pins a+b then that would be fine.
Old Nov 1, 2004 | 11:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sounds like a wire hackers nightmare come true.
Old Nov 1, 2004 | 11:20 PM
Car: 85 Camaro Z-28
Engine: 6.6
it is! but do you know about the scan tool, does it only use the 2 pins A+B or does it use the rest? hopefully it only uses 2 lol
Old Nov 1, 2004 | 11:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The scan tool depending on which model and manufacturer generally uses between 4 and six pins to get there readings. They are pins "A", "B" "C", "D" & "E", sometimes "F" & "G"
Old Nov 1, 2004 | 11:35 PM
Car: 85 Camaro Z-28
Engine: 6.6
****! hmm o'well ill just have to live with it for now i guess. not sure exactly what would cause this in the first place but dang this is confusing, sometimes i think i should just put a carb on it. lol naw iv got too much time and money into it now.....
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
