What is the correct Timing?
Car: All GM
Engine: All Chevy
Transmission: TH350 / 700R4 / 4L60E
Axle/Gears: custom GM 8-1/2" 456 posie
Can anyone tell me what the correct timing is for a 1987 5.7L TPI GTA is? The car has a separate coil, and is running a 700R-4. It is fully loaded including digital dash and A/C. The motor has been rebuilt, to as close to shock as possible. 30 over, stock cam 10/10 crank etc.
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: What is the correct Timing?
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Factory base timing is 6 yes, but w/ motor, use as much as you can w/o pinging...
Car: All GM
Engine: All Chevy
Ok thanks again
Thanks again.
My wire harness is made by "Painless" and it is a closed loop type.
I disconected the tan wire with the black strip at the computer and set the bass timing at 8' B.T.D.C.
I'm not sure if my Throttle Position Sensor is set correctly, if it is not will the timming still be correct? Or does the Throttle Position Sensor have to be adjusted correctly before I can get the timing correct?
Car: 88 Camaro
Engine: L98 350
The two are not connected. Have to really rev some before the module advance comes on with the timing set connector unhooked. Just let it idle and check timing.
Ghettobird52
Jul 5, 2024 11:18 PM
Linson
Aug 21, 2015 02:12 PM
