Misadjusted TPS and vaccum leak cause same problem?
Car: '88 Red Trans Am w/ T-tops
I thought for the longest time that my car had a vacuum leak and it still may. I just recently had to adjust my TPS. It was set to .054 instead of .54. Would this cause the car to idle the same way that a vacuum leak could. I never can find a vacuum leak but it ran like it had one. Now it runs better. Any advice or insight?
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Misadjusted TPS and vaccum leak cause same problem?
Originally posted by Trickster
Were you getting a code 21, 22, or 33?
Re: Re: Misadjusted TPS and vaccum leak cause same problem?
Originally posted by CaptPicardsZ28
I thought you fixed your problem in another post? People told you that you may have a vacuum leak when you asked the first time. Then you said you found out that the tps was off and you fixed it and it runs fine. You dont have a vacuum leak cuz if you did it would cause some of the same type of symptoms. There is no advice or insight to give you, You checked everything and there isn't a leak anywhere. Go and have a nice day...
