305 Oil pressure
Old Nov 8, 2004 | 11:37 PM
sam's Avatar
sam
305 Oil pressure
Well,
I changed my oil yesterday at JiffyLube and they put in 10-30 penzoil and a new filter. On the document i got it said they put 4 quarts oil. I think to my self that does not seem right for a 5L V8. Is it correct?
Ever since that oil change my pressure is way down. So low it is scarry. If am in neutral and put it in drive the presure drop to ZERO !!! Then works its way up to about 15-20 PSI. (When engine warm)
If
I did NOT have that problem prior to the oil change, so I am puzzled
What can cause oil pressure to be so low?
Please help
Sam
Old Nov 8, 2004 | 11:40 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: 305 Oil pressure
Originally posted by sam
Well,
If
Please help
Sam
umm have you checked the oil since the oil change ???
if not id suggest it and then your probably gonna see that your a quart low .....
Old Nov 8, 2004 | 11:58 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
being a little low on oil is not going to make your pressure drop that low... if i were you id replace the oil pressure sending unit then if the problem is still there then id be scared... but my guess is that your sending unit is ****ting the bed man.... mine has done the same exact thing to me on all 3 camaros that i have oned in the past...
Old Nov 9, 2004 | 12:05 AM
anondude13's Avatar
I second the oil pressure sender. If you're really that worried, go to autozone and buy a $15 mechanical pressure guage. And yes it's supposed to take 5 quarts, check the dipstick. Finally, why pay jiffylube to do what you can do yourself.
P.S. If you really had 0 pressure, you would know it.
Old Nov 9, 2004 | 01:36 PM
sam's Avatar
sam
Hi,
Well, as far as the oil level it is hard to tell since it is so transparent but it seems to be at the full mark.
So if i really did get as low as zero the engine would have shut down?
Sam
Old Nov 9, 2004 | 06:39 PM
THEGENERAL's Avatar
Hi,
Sam
i would get a mechanical gauge and see what is actually going on ...
Old Nov 9, 2004 | 08:43 PM
rudyt5000's Avatar
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
well i also have a problem with my oil pressure guage after a lil race ....it goes crazy up and down i had the o-rings replaced on the sending unit....it worked okay till i gave it some gas....now it does it again...should i be worried . i still drive it and it runs okay ....shop told me it had to be replaced but low on funds
p.s. beat that stang in da 1/4 but tpi runs out of steam in top end
Old Nov 10, 2004 | 09:39 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Yes... and not in a happy, just restart it and go type way.
Old Nov 11, 2004 | 10:14 AM
sam's Avatar
sam
I bought a pressure sending unit but i cant see it on the engine with the hood open... Do I need to go under the car inorder to install it?
Before i do change it i want to know from those who have changed and as a result solved the problem. Was your meter acting funny, eratic shifting left right? or was it moving steady prior to the change? I was told by the mechanic that if it moves slowly then nothing is wrong with it...
I am assuming that it is more probably the oil. lower viscosity than what the previouse owner had put in it. I used 10-30 What do you guys use?
Thanks,
Sam
Old Nov 11, 2004 | 12:24 PM
rudyt5000's Avatar
here's some experience from others...
https://www.thirdgen.org/techbb2/sho...+unit+location
Old Nov 11, 2004 | 04:22 PM
deadbird's Avatar
Engine: TPI 305/ v6
Early style sender were 'bell' shaped and next to the distributor (drivers side). They had a single wire.
Newer style was intergrated into the oil pressure switch located just above the oil filter. It has 3 wires.
My '91 has the newer style and when I bought the car, oil psi was 40ish on a cold start and would drop to nil after about 1-2 miles. A replacment sender later and the car is running 55psi cold and 30-50psi at operating temp.
Old Nov 11, 2004 | 10:24 PM
sam's Avatar
sam
Well,
I have now replaced the presure sending unit and that did not change anything other thatn that it does not drop all the way to zero. instead it is constantly at 15 PSI when in neutral or in gear. (stoped) while driving it is about 28-32.
So I want to know then what oil some of you use in your 86-89 V8. It can be no other thing then the different oil i used.
Thanks,
Sam
Old Nov 12, 2004 | 12:26 PM
anondude13's Avatar
_
Old Nov 12, 2004 | 07:47 PM
sam's Avatar
sam
I would buy a new gauge if i could afford one at the moment... dont they run at about 40 50 bucks? Knowing it is not the sensor leaves the actual gauge that can be faulty or even the engine...
However, it no longer goes to zero even with the foot on brake and in gear. 15 is the lowest it goes.
I would rather have a working gauge in the original position than mounting one by the window...
Sam
Old Nov 12, 2004 | 08:25 PM
anondude13's Avatar
The guage will be about 15 dollars. Don't leave it connected after the test to avoid a potential oil leak. You would only be using it as a diagnostic tool. It's better to lose 15 dollars buying a guage than buying an oil pan gasket and having to hoist the engine and all the other stuff involved in an unnecessary oil pump change. I think 15 is too low, but I'm not an expert on where oil pressure becomes dangerously low.
Old Nov 13, 2004 | 07:53 PM
rudyt5000's Avatar
well i finally fixed my car from over heatin ...fan relay .....but after checkin da thermostat first and breakin a bolt ....but yeah i said my oil gauge was eratic going up and down....but now its steady at 15 also and goes down to zero sometimes when at a stoplight....but even addin oil doesnt change it...maybe time for an oil change & filter .....but i also have to replace sendin unit from what i was told by the shop.....it still goes up and down wild..but it usually never went down 30...but now i guess replacing oil sendin unit and possibly oil pump might be some new experience....by the way SAM does your car make a suckin noise when you hear the engine idling ? ??? cause mine does and sounds like its in da rear of the block
Old Nov 13, 2004 | 09:43 PM
sam's Avatar
sam
I agree that 15 might be low but i dont worry about it much since it jumps to about 30 while driving.
Rudyt5000, I have not heard such a noise it sounds like everything is working okay. No strange sounds. By the way mine stoped going down to zero. keep us uppdated if you get it sorted out
Sam
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
