can i stroke my 350 TPI?
Old Nov 18, 2004 | 08:32 PM
jasons91z28's Avatar
Car: 1991 camaro Z28
Engine: 5.7 v8 350
ive been told by many people that my Z can my stroked but i have also been told that since it has a ecm i cant stroke my 350. If it is true what esle would i need to do besides the rotation assembly, like better fuel injectors? somebody set me straight here.
Old Nov 18, 2004 | 10:45 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Whoever told you your 350 tpi can't be stroked shouldn't be allowed to touch cars, ever. Yes it can be stroked. You'll need a custom EPROM chip for sure, as the speed density system you have makes assumptions based on the map which will no longer be valid for a different displacement motor, which will likely have a different camshaft. You will want your heads ported or (better yet) replaced with something better flowing -- a long stroke engine really needs good heads. Yes, larger injectors would be a good idea, at least 24s to start with. Your eprom will have to be programmed specifically for the size injector you choose. You will probably want a bigger throttle body than stock, although you could use the stock one if you had to. A stock TPI base manifold and runners are barely adequate for a 305, so for a 383 they will be largely inadequate. If you're looking to make power, you'll want to look at aftermarket manifolds and runners for the 383.
Definitely not a cheap route to go, but yep you can stroke it and keep a TPI.
Old Nov 18, 2004 | 11:05 PM
C20T/A's Avatar
Car: C-20
Engine: 260 boat anchor Mexican 350 (crate) TPI (MAF)
Transmission: THM-400 I turn 3500 (which is where my pos engine's power starts droping off) at 80 I need a 4L80-E
SHURE IT CAN
Old Nov 19, 2004 | 06:14 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
If your going to stroke it go with a 396 every one and there grandma has a 383..lol
Old Nov 19, 2004 | 06:17 PM
formula91's Avatar
Car: 92 GTA
Engine: Yes
Transmission: Busted
You can stroke it, just make sure you've let it cool down otherwise you'll burn your hand.
Old Nov 20, 2004 | 10:31 PM
vwdave's Avatar
Make sure you use lube too. You dont want to cut...err, chip the paint.
Old Nov 20, 2004 | 10:36 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Originally posted by C20T/A
SHURE IT CAN
:werd:
Old Nov 20, 2004 | 11:21 PM
90Formula305's Avatar
Car: 1990 Pontiac Firebird Formula
Transmission: 700 R4
Axle/Gears: peg leg
TPI isnt speed density is it, my friends tpi is mass air flow and it just reads different changes in the motor and compensates for it.
Old Nov 20, 2004 | 11:33 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
91-92 TPI = SD
Old Nov 21, 2004 | 12:49 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
91-92 TPI = SD
You forgot 90.
Old Nov 21, 2004 | 11:36 AM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Stroke it...if I ever have to replace the motor in my car again, it will get stroked. If I do, I will go with either a 396 or if there is anything bigger than that, I may consider the larger cubes
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
