1.6RR would it help my current setup
Old Nov 25, 2004 | 06:30 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
mods are in my sig. would there be gains? is there a downside to that much lift? or should i leave well enough alone . the rockers are comp magnum roller tipped.
Old Nov 26, 2004 | 12:19 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If your heads can take the added lift, go for it.
At that amount of lift and duration, it wont hurt a bit.
Old Nov 26, 2004 | 05:35 AM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
according to edelbrock the springs should handle .560 lift. what about tales of wearing guides? there has to be a down side is it durability? over some time?
Old Nov 26, 2004 | 09:01 AM
Abubaca's Avatar
Wearing guides can be an issue. From what I understand, it kinda hit or miss.
...I've also always heard that the biggest gains from 1.6 comes from the fact that they are typically higher quality than OEM stamped rockers, and don't flex much. Someone did a comparison and found a noticeable difference going from OEM rockers to 1.52 and 1.6, but didn't see much difference between the 1.52, and 1.6. Both made a difference.
....I did a search a few months back, and I don't remember who posted those results...
Old Nov 26, 2004 | 09:52 AM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
the 1.6's i have are brand new. so i should sell um and get the 1.52 versions. i definatly dont want to tear down the motor within the near future.
Old Nov 26, 2004 | 03:40 PM
Abubaca's Avatar
I think I read that most of the problems with the guides are on factory heads, and you have the Edy's according to your sig. I "THINK" you should be OK, but I may do some more research.
...not sure how it'll actually affect performance.
Bubbajones_ya
Jul 6, 2024 08:32 PM
86Firebird86
Dec 26, 2015 07:21 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
BDR
Nov 7, 2015 03:05 PM
customblackbird
Oct 1, 2015 04:30 PM
