pics of 388
Old Nov 27, 2004 | 07:59 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
pics of 388
want to get ideas on intake choices, this is what i got
Old Nov 27, 2004 | 08:00 PM
more
Old Nov 27, 2004 | 08:01 PM
sorry about the last
Old Nov 27, 2004 | 08:03 PM
one more
Old Nov 28, 2004 | 06:35 PM
SSnthe10s's Avatar
Car: 1992 Firebird
Engine: 350 with vortec heads
i would just go with the Edelbrock performer RPM. great intake for street use.
and also why do your pix suck so bad?
Old Nov 28, 2004 | 07:36 PM
uhhh yeah the performaer would be great if i was going carbureted, been there done that, this motor is going under my tpi in my 86 iroc, i just dont know the best intake combo for it with fi. uhh i think the pix sucked because i was half asleep when i took them and wasnt staying still. anyway, what fi intake would be best for my motor?
Old Nov 28, 2004 | 10:19 PM
psidy's Avatar
Ever consider the Mini-ram III?
Old Nov 28, 2004 | 10:20 PM
TPIJeep's Avatar
Engine: 7.4 L of Small Block Fun...
Stealth ram, thats a big intake port probably going to need Felpro 1206 intake gaskets..
Old Nov 28, 2004 | 10:37 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
HSR doesn't fit the Fastburn heads, hence the MRIII.
As for the intake choices, carb or EFI?
Old Nov 29, 2004 | 12:26 AM
efi is the way im going, i guess my choices are the mini ram or buying the sdpc base or waiting for the hsr for vortec motors
Old Nov 29, 2004 | 11:50 AM
KiLLJ0Y
Guest
Posts: n/a
screw the mini ram, buy the LT4 intake from Summit, its 299$ the heads will match, and the mini ram is just like the LT4 without the price.
Old Nov 29, 2004 | 12:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
true, i recommend the LT1/LT4 conversion for it. cheaper than mini ram, but will make similar power. LOL
Old Nov 29, 2004 | 12:05 PM
yes, i wanted the lt1 , but in talking with john millican , he says the lt1/lt4 intakes will not fit thses heads, that i am in the same boat as the vortec guys, but, i was able to run any carbureted intake i wanted on these heads as long as i used the 1266 felpro gasket, i dont see where the difference would be from the converted lt1 and a regular smallblock intake fitting on these heads, they did come with both regular smallblock holes and vortec holes, i wonder if when i have used the 1266 that it has sucked it up enough to make up the difference?
Old Nov 29, 2004 | 12:14 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
how about the GM ramjet intake? I think you can pick up the intake and fuel rails for less than $500(but don't quote me on that), find an LS1 throttle body, and it should work...I don't know if the intake will cover those ports, but it does have a vortec intake pattern, and its less than the mini-ram.
Old Nov 29, 2004 | 03:01 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
i would just wait for the vortec stealth ram its definatly gonna be the best bet as far as dollars vs performance goes
Old Nov 29, 2004 | 04:58 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
One more option.. I dont know if the vertech base is done yet or not. E-mail ken and ask. Verry nice guy.
http://www.firstinjections.com/
Fits a felpro 1206/7 right outa the box. has been ported to a 1208 buy a guy running one in his vette.
Old Dec 7, 2004 | 06:00 PM
I TEST FITTED A STOCK TPI BASE ON MY MOTOR WITH A 1266 GASKET AND IT LINED UP PRETTY WELL, ANYONE KNOW ABOUT IT:lala:
Old Dec 8, 2004 | 05:29 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Itll sit on there nicely....but do it again and look down your intake bolt holes.
Old Dec 8, 2004 | 06:23 PM
do you think i could just re drill the intake holes a little and use some small washers maybe with some grade 8 intake bolts and get it to work?
Old Dec 8, 2004 | 10:25 PM
Car: 89 Formula
If it was possible dont you think we would have all done that?
Just a question.
Old Dec 9, 2004 | 07:28 AM
well i dont know in talking to a lot of yall A) some have never messed with fastburn heads in person B) have never messed with 1266 felpro's. that is why i asked the ? because when this motor was carbed before the refresh i could get a regular smallblock intake on it with the 1266. my main ? is is there a size difference between a regular sbc base and the tpi base?
Old Dec 9, 2004 | 08:58 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Jay, do you still have the red car?
Holley makes the Stealth-ram for vortec heads now!!
Go with the vortec/fast-burn stealth-ram.
Mike
Old Dec 9, 2004 | 11:49 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
No, the bolt holes are just different
Old Dec 9, 2004 | 12:05 PM
they probably wouldnt fit the intake ports anyway, ill just get the vortec stealthram
Old Dec 9, 2004 | 12:12 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
There was a Miniram III for vortecs on ebay for $500 a few days ago, might want to look into that.
What size intake gasket do those fast burns take? I know the stealthram is limited to 1205 or smaller IIRC. I just seem to remember people saying 1206s are too big...
The fast burns are probably a 1205 though (190ish cc intake runners)
Old Dec 9, 2004 | 12:38 PM
when they were ported they were ported for a 1206 or 1266, they flowed around 310cfm at 550 lift on the 2.08/1.65 valves
Old Dec 9, 2004 | 01:31 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
If you port em that far Im sure you have to re weld them to add some material... or they are super thin when ported to 1206s
Old Dec 9, 2004 | 09:07 PM
all i know is they match up to a 1266 perfectly , didnt have any welding done or anything like that
Old Dec 9, 2004 | 11:36 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I go with the miniram III but thats me I don't like the way the stealth ram looks
oh fast burns are 210cc
Old Dec 10, 2004 | 06:32 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
We we talking about different things
Im worried about matching the intake to your heads. I researched a bit and found this pic, and the only difference in a 1206 and a 1266 is .04", so they are almost ths same..
www.stealthram.com
This pic is of the HSR intake...
Old Dec 10, 2004 | 07:15 AM
thats what i thought, the 1266 is double the thickness though? that means that i should be able to make the regular stealthram work right?
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
