Cam question....again..
Old Dec 6, 2004 | 11:14 AM
Jonas.O's Avatar
Car: Camaro IROC Z
Transmission: TH700R4
Ok as the subject says; I planed to change my stock camshaft to something more "hot". Anyone got any suggestions? I got stock manifold, stock runners and ported plenium, AFPR @47PSI, custom chip, and a 2,77 rear end. I planed to port the stock heads too.
Old Dec 6, 2004 | 12:13 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Not much point without swapping out those highway gears. You'll lose low end torque that you desperately need to get the car moving. The car will probably be slower than it is now.
Swap up to a 3.73 gear and then start thinking about a cam and doing headwork.
Old Dec 6, 2004 | 12:31 PM
Jonas.O's Avatar
Car: Camaro IROC Z
Ok, but how will it work with my speedometer then?
Old Dec 6, 2004 | 12:42 PM
You'll just need to swap the speedo gear for a correct one. What year is your car? Mechanical speedo cars are easy. It's a simple gear swap. I'm not 100% sure how to handle an electric speedo because I've never dealt with one, except my Autometer, which is self calibrating.
Old Dec 6, 2004 | 01:10 PM
Jonas.O's Avatar
Car: Camaro IROC Z
It´s an -88 and I think thous are mechanical, do I have to reprogram the chip then?
Old Dec 6, 2004 | 01:15 PM
If it's an '88 Camaro then you have a mechanical speedo and all you have to do is pull the speedo drive out of the trans, change to the right gear, and pop it back in. It will literally take you longer to get the car up on jackstands that it will to do the work. Any Chevy dealer should be able to get you the right gear if you give them the tire size and rear end ratio.
Old Dec 6, 2004 | 01:46 PM
Jonas.O's Avatar
Car: Camaro IROC Z
Ok I will check with them, thanks a lot.
Old Dec 7, 2004 | 07:10 AM
No problem. Feel free to PM me if you need any further help.
Old Dec 7, 2004 | 11:36 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
When I first put my 355 in I had the LT4 hot cam and 2.73 gears. starting from a stop sucked. It took a lot of clutch slipping and a fair amount of gas. The 3.45 are great now. World of difference. You will want to change the gears. My MPG even went up. Probably because at leat 1/2 of my driving is city/town.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
