Tpi Power
Old Dec 7, 2004 | 08:23 PM
camarokidirocz's Avatar
Car: 1989 iroc-z camaro auto
Engine: stock 5.0 TPI
Transmission: auto
Tpi Power
how do i free up horses on my tpi without emptin my wallet. and what emmisons controls can i take off of the car because we dont have vehicle testing here in kentucky:lala:
Old Dec 7, 2004 | 10:07 PM
nosaj 86irocz's Avatar
Car: 86iroc
From what i understand more air,hi po air cleaner,remove screen from mass air flow sensor,more fuel, adj fuel reg. Am i correct ?
Old Dec 7, 2004 | 10:56 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Start with a good exhaust system, headers, catback, everything...
Old Dec 7, 2004 | 11:18 PM
Abubaca's Avatar
Welcome to TGO.....and post a pic of the ride!!!!
.....What's your budget? If you're talking about the nickel and dime stuff, then exhaust is outta the picture. Maybe just a Carsound cat and a catback? A hooker catback and carsound cat can be had for under $400. Headers will be between about $350 and $500 plus coating, plus intallation if you're not doing it yourself.
The nickel and dime stuff would be stuff like removing screens, although I don't necessarily recommend that. Air Filters of course. You can cut the airboxes UNDER the air filters too, that'll help a bit. The adjustable fuel reg. can add a few and it's not too much...less than $100.
What are your goals, and what's your budget???
Old Dec 8, 2004 | 08:34 AM
brutalform's Avatar
If a car has dual cats, then I would modify the intake. Correct me if Im wrong, but didnt a few 89s slip through with dual cats? These exhausts flow more than the single cats...Tom
Old Dec 8, 2004 | 11:41 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Some 89s had duals cats you are correct.
Im with the others, I need a budget to get moving
Old Dec 9, 2004 | 10:52 AM
greenfrogg's Avatar
Car: 89 FORMULA355 80 TURBO TA 355
Engine: 355 tuneport 355 chev CARB
Transmission: 700 350
my 89 formula350 came with dual cats
Old Dec 9, 2004 | 12:16 PM
Abubaca's Avatar
....the dual cat was with G92 package. ...and yes it was available in 89. I thought it was an option in 88 too, but have no info to back that up.
.......what are your goals?
Old Dec 15, 2004 | 06:37 PM
l98+t5's Avatar
Car: 1988 camaro iroc-z z-28
Engine: L98 5.7 liter 350
Transmission: T-5 manual 5-speed
yep they had that option in 88 cuz i got one
Old Dec 15, 2004 | 10:16 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
Get headers, a full exhaust(headers, a muffler and pipes), grind the walls behind of the plenum out(behind the TB), shift kit(TransGo!)gut the air boxs, install a good set of air filters(K&N, Kool Blue by Accel or such)and you will be running pretty good.
Old Dec 21, 2004 | 08:20 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
leave the screens alone on the MAF . It has caused idle problems for other people. Rich idles , etc . Kinda need to know how much $$$ you got to spend . It isnt cheap to do any of this stuff really . You will slowly find everything seems to add up to more than you anticipate aswell
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
