low 13s
Old Dec 30, 2004 | 03:38 AM
unbonyr's Avatar
low 13s
you think this setup will get me in the low 13s
HSR-800
zz9 cam-350
trick flow's 23-800
slp headers-500
slp exshast-500
roller rockers 1.5-350
3.42 gears-300
etc. igniton, machining, air filter.....-500
injectors 24lb-300
tires-600
chip,prom-500
stall converter 2400-250ish?guess
so thats around 6g do u think most of my numbers are correct thats alot more then i want to spend on the motor so if theres some things i can cancel out to get lik 13.35 or under let me know also everybody running et streets but i looked at the et street radials and i like those thread patterns alot more anyone have those and how u like them also can u run et streets on a daily driver cuase i really want tires i can daily drive and they prob see the track once a month
Old Dec 30, 2004 | 08:18 AM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I'd be extremely surprised if that didn't get you deep into the 12s on good tires
Old Dec 30, 2004 | 11:42 AM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
unless your partial to the motor....i would just swap in a better or bigger one for less than 6g... but thats just me
Old Dec 30, 2004 | 12:07 PM
subliminal's Avatar
Just get a supercharger and a good tune, 3500 for one out of summit.
Old Dec 30, 2004 | 12:36 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
Is that on a 350 motor??
Old Dec 30, 2004 | 04:07 PM
unbonyr's Avatar
yes it is its an 89 gta trans am 350 tpi around 60000 on the rebuilt motor around 50000 on rebuilt trans but thats roughly around 6g i would really like to spend around 4500 on everything on the motor and go around low 13s
Old Dec 31, 2004 | 01:03 AM
unbonyr's Avatar
wat u mean by a tune up
Old Jan 1, 2005 | 05:04 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
If I can get the car to hook and if I learn how to drive I should be able to hit low 13's with just a 96 LT1 cam and all the other lil sh<x>it I've done. So far the best that the IROC has ran is 13.7@103.xx
Kat
Old Jan 1, 2005 | 06:30 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: low 13s
HSR-800
zz9 cam-350
trick flow's 23-800
slp headers-500
slp exshast-500
3.42 gears-300
injectors 24lb-300
tires-600
chip,prom-500
Some of your prices seem off.
I'd tune you rown chip.
I'm in the process of rebuilding my engine right now. My long block cost $3500 for parts and machine work. (only thing re-used was the block itself).
I dunno what ET it will run cuz I use street tires, but I'm guessing around 130mph in the 1/4. Prolly 10.99 or so on slicks .
Old Jan 1, 2005 | 08:10 PM
vwdave's Avatar
Definate 12 in that.
Old Jan 1, 2005 | 11:12 PM
unbonyr's Avatar
ok what if i did all those mods ive listed but instead dont get the roller rockers forget about the tires unless you can tell me a tire that has great traction but yet that can drive in the snow ok and the other good stuff like threadlike and daily driven but can be driven hard on the street i can also get the HSR for lik 650 instead of 800 do you also jumping from 3.27 gears to 3.42 gears would justify 300 dollars how much track time would you think i would gain by doing it so with all that said do you still think i can go in the low 13s without the rollor rockers and without some slicks oo yea that now puts me at about 4100 dollars without tires which is about what i wanted to spend on the performance of my car and get low 13s so with this setup you think i ll have my goal thanks
Old Jan 1, 2005 | 11:19 PM
unbonyr's Avatar
also will i pass emisions with the HSR if they only thing they test is how much pullition im putting out(sticking a tube up my tail pipe) but no visual test or any other kind of test
Old Jan 1, 2005 | 11:23 PM
vwdave's Avatar
If you do some smart shopping, you should be able to save a little more money.
IMO, dont get a SLP exhaust, goto a muffler shop and let them do a setup for you. You'll probably save money on just that. $300?
I am running a L98 Corvette torque converter which stalls at about 2400 in my car. $100 from a transmission shop.
HSR is about $550-600 from summit.
LT1 injectors are 24lb I think. Ebay or junkyard.
Dont change your gears. Youre not going to notice a huge difference.
As for emmissions, youre on your own. In florida there is no testing.
Supposedly, the BFG KDWS is pretty good.
Old Jan 1, 2005 | 11:54 PM
unbonyr's Avatar
thanks man alot i really appreciate it out of the 10 theards ive posted this is the only one were im really figureing out what i want ok so what about tires are there tires that are good as daily drivers but still get respectiable traction also should i beef up my trans its an 700r4 and i was thinking a pro action rebuilt i did get my trans rebuilt like 50000 miles ago so and how much is it for the pro action rebuild do you think it be worth it
Old Jan 2, 2005 | 12:24 AM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
A couple years ago I had real bad leaking valve seals. I bought a set of edelbrock aluminum 2.02 heads with 64 cc chambers and ran 13.30's with the rest of the bottom end of my motor bone stock.The only other work I had done were all free mods.
Old Jan 2, 2005 | 01:09 AM
unbonyr's Avatar
whats all the free mods and you ran it on street daily driven tires no special ones
Old Jan 2, 2005 | 04:54 PM
robsgta's Avatar
Free mods :
Remove maf screens and aluminum fins in MAF.
Make a homemade cold air intake with 3 inch vent tubing & k&n air filter.
Remove aluminum material behind throttle body blades.With air grinder or dremel tool.
move intake air temp sensor infront of the throttle body.
other things that could contribute to better time would be a fuel pressure regulator.
a tune up with better wires than stock and better coil.
I ran my 13.30 with bfg drags I still had some tire spin but a whole lot less than with a street tire. You have to invest in some sticky tires first or your never going to know the potential of your car in the 1/4.
Old Jan 2, 2005 | 04:56 PM
vwdave's Avatar
Good advice. I am constantly fighting with the ****ty BFG Radial TA's for traction.
Old Jan 2, 2005 | 05:24 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
In those 10 threads, have you included a single punctuation mark or capital letter?
Old Jan 2, 2005 | 05:30 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Thats a negative ghostrider. The HSR is a non-emissions manifold. It was designed off of the tunnel ram for carburetors, which was never meant to be emissions compliant.
Old Jan 2, 2005 | 05:40 PM
unbonyr's Avatar
so theres no way to pass emisions if the only thing they test is my gas polition then how are all these people with hasr running them illegal
Old Jan 2, 2005 | 06:04 PM
unbonyr's Avatar
also so you really think i should buy some new tires costing me what around 575 dollars just to take to the track once every 2 months and this is a daily driven car and i do alot of road races not serious like no fast and furious but if a person at the stop light gives me that nod thats when i like to race
Old Jan 2, 2005 | 06:07 PM
brutalform's Avatar
Old Jan 2, 2005 | 06:08 PM
White91GTA's Avatar
Engine: 5.7L TPI
they live in states that don't require you to have emissions inspections or they are strictly race cars that dont have to pass anyways.
Old Jan 2, 2005 | 08:29 PM
unbonyr's Avatar
ok thank you thats what i thought so i can run HSR legally
Old Jan 2, 2005 | 09:31 PM
robsgta's Avatar
Here in Texas they test your exhaust gasses and look under the hood but really dont know what there looking at most of the time. All there main concern is that it passes the emissions part not the intake brand or style.
Theres always a way to pass an in$pection.
Falcon50
Aug 22, 2020 03:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
