Hawks Ram Air Kit
Old Jan 10, 2005 | 07:55 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
Hawks Ram Air Kit
How good is it? I have been wanting to possibly buy it this week but I wanna know if anyone on here has it and if so did you feel a difference with it on the highway and at the track. Or maybe I could go for the SLP CAI and spend a lot more for it but I am leaning towards the Ram Air Box(s)only because I like the way they look and even if I get less HP with it, I am hopeful it will still add some decent horses. Thanks.
Old Jan 10, 2005 | 07:59 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
I belive that the ram air box you are refering to needs "the ram air 2 hood" to work, it wont eaven fit under your stock hood. So be shure to ask Hawks about it before you spend the money.
Old Jan 10, 2005 | 08:11 PM
Well this is just for the metal box(s). The one that grabs air from behind the fog lamps. It can be used with the Ram Air air box & filter but it may also be used using the stock air lid.
Old Jan 11, 2005 | 02:33 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
not worth the money when you can make your own I used this to do mine https://www.thirdgen.org/newdesign/tech/ramair.shtml
this is the box's he's talking about
Old Jan 11, 2005 | 08:06 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I wish i was still working in sheet metal. I could turn out 5 of those an hour. Proably more...Just cut them out on the bandsaw, run them thru the pittsburg machine, couple hems, hammer them together. probably have to roll the back/front side to get good air flow. so easy to make. Nothing more than and elbow with flanges.
Old Jan 11, 2005 | 07:47 PM
Thanks guys. Well I did make my own ram air with dryer hose and a few bolts nothing fancy but whatever. I need to make the box(s) when I got some free time. We'll see what happens. Thanks for the info fellas.
Old Jan 13, 2005 | 12:51 AM
KiLLJ0Y
Guest
Posts: n/a
look on ebay, there is a guy who sells the same thing for 49$. thats if you dont want to do it yourself.
Old Jan 13, 2005 | 03:37 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Here is what I did.... cost me 6 dollars ....and works nice. But remeber to clean them airfilters alot
hiope it helps ...I got it from Home depot ...furnace duct
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bryan623
Aug 10, 2015 11:33 AM
drathaar907
Aug 6, 2015 04:20 PM
