Rough Idle
Old Jan 12, 2005 | 08:32 PM
Dustin89GTA's Avatar
Car: 1989 GTA
Engine: 355 TPI
Transmission: 700R4 (w/ shift kit)
Axle/Gears: 3.27 (stock)
Rough Idle
I have a brand new engine 174 miles. The cam is a custom grind and loves rpm above 2000. It will jump around when in park which I expected. However when sitting at a stoplight in gear it almost stalls out.
Will a custom ship help the idle?
Old Jan 12, 2005 | 08:35 PM
Car: 1989 GTA
Engine: 355 TPI
I can't spell
Old Jan 14, 2005 | 09:54 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
raise your idle
Old Jan 14, 2005 | 02:01 PM
Car: 1989 GTA
Engine: 355 TPI
with the set screw?
Old Jan 14, 2005 | 02:04 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Need more info on engine and setup, but if it's much different than stock you probably need a new prom burned....
Old Jan 14, 2005 | 02:21 PM
Burning a custom prom would be the best. But if you need a temorary solution turn the screw and raise the idle speed enough to keep it running
Old Jan 14, 2005 | 03:01 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
double, tripple check for vacume leaks.. last time i tore into my motor for mods, and it didnt idle, it was vacume leaks runner to base runner to plennum etc. i used carb cleaner to find mine.
Old Jan 14, 2005 | 03:47 PM
Car: 1989 GTA
Engine: 355 TPI
I've been thinking about burning a chip, but I won't be able to work on the car for a while, it's in storage now, (Iowa winter).
thanks for the help
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
IROCtometal
Sep 2, 2015 02:01 PM
