Throttle Position Sensor not touching throttle body piece, voltage reading 1.9
Old 01-15-2005, 02:52 PM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
Alright here is a STUMPER, the TPS is working FINE, but the golden metal piece that touches the arm on the sensor is NOT touching at idle and making me run rich as a SOB, I don't know how to fix it? I am driving my other vehicle while this one is acting funny.
Old 01-17-2005, 07:33 PM
Vader's Avatar
Have you tried to manually return the TPS lever to the "closed throtle" position?
Old 01-18-2005, 09:02 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
if the TPS is sticking, might think about cleaning with electrical cleaner while moving the the tps lever. if not, just replace it and re-adjust.
Old 01-18-2005, 02:57 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Sounds to me like your TPS is anything but "fine"... more like in dire need of replacement.
Old 01-18-2005, 03:41 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
what is it sopostoo be set at
Old 01-18-2005, 05:49 PM
TechSmurf's Avatar
Engine: LS1, Scrap
.54-.56v at idle
Old 01-18-2005, 08:52 PM
Damon's Avatar
You wouldn't happen to be using an aftermarket throttle body, would you? By, say, Holley? If so, I've got your fix.
1992 Trans Am
05-10-2023 07:19 PM
Azrael91966669
25
06-20-2017 04:04 AM
bamaboy0323
08-15-2015 07:20 AM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: Throttle Position Sensor not touching throttle body piece, voltage reading 1.9
