Who has the quickest Mass Airflow car?
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Just wondering how quick cars have gone with a mass airflow meter as apposed to a speed density set up.
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
i dont know if preston smith's car is still MAF or not but if it is it has to be one of the baddest in the world
Car: 1989 Trans-Am
Engine: 454-Motown SBC w/HSR
Transmission: 6-Speed
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The fastest MAF car? Proably someone with a 5.0 Mustang! Much better engine management system than the GM MAF system.
Car: 1971 Camaro
Engine: 427
Okay, let me be more specific. Who has the quickest 3rd Gen Camaro with a Mass Airflow Meter Equiped Engine management system?
I knew what you meant. Just had to put that out there. It's a good question though. And, are they still running the stock MAF meter? I'll tell who's doesn't have the fatests MAF car: me!
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
There was a guy on here that was named ski_dwn_it. He didn't have a 3rd gen, but it was a TPI vette, so it's pretty close. He still used the MAF and was making hella HP. He was booted from the site for not agreeing with some members/mods here, but a search can find that he was making 438 RWHP on the dyno, which is around 600hp up top.
He was using a 406TPI with SuperRam intake, but still had the MAF metering system. People still don't trust the dynomometers, so you will need to find is times.
Originally posted by TPI-454
I still have that article from Hot Rod; "Kinetic Engineering". 1985 IROC, Supercharged 305 TPI, running in the 10's... yet looks bone stock!
That he was a pioneer in the TPI. The fact was no one made parts for the cars then. In the S/S article, he was going 10s with the 305..relying on Extrude Hone process and all...Then in GM High Tech, I believe he was going mid 9s.
Found it. May 1998 GM High Tech, he was 9.95/135.
Best 60 ft. 1.37. all with 24 p.s.i. of boost.
He and the car suffered a bad accident. Alls good now. Recently he had the car submitted in the Hot Rod pump gas street drags. Im not gonna get into the rules here, but he was not picked anyway. Just a little FWIW.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yep Jessie is the one I was also thinking of. The times you listed are pretty close. He posts on the Corvette forum. Allen
Car: 1989 Trans-Am
Originally posted by brutalform
But I do remember "Kinetic Energy" from way back, (about 16 yrs. or so) in Super Chevy. That he was a pioneer in the TPI. The fact was no one made parts for the cars then. In the S/S article, he was going 10s with the 305..
Preston's 1985 305 TPI Burgundy (T-Top) IROC (looks bone stock, runs 10's, and gets 20mpg). If anyone care's to read it, I honestly don't mind posting it. It's a great read!
Yes, that's the one. I got mixed up with Hot Rod, but it's definitely Super Chevy... I'm looking at that very article as I'm writing this; "Kinetic Engineering".
Post back here and link the threads if you can, or at least let us know what the new thread is so we can follow it.
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
i put out over 575 to the wheels on a 150 shot on a stock chip with my maf on a dyno last week so i know you can make power. ill try to scan my dyno sheet so yall can see
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
probly one of the LS1 or LT1 swap guys.....
Car: 92 Z28
Engine: Boosted LSX
This is his last know setup when I talked to him
Vehicle is modified to improve in five areas: Acceleration, Braking, Handling, Ride, and Appearance, while maintaining original Eng. Disc. and 4-speed O.D. transmission with some compromises, while being driven a minimum of 8k miles/year and obtaining 20 MPG.
TECH SPEC’S
BLOCK- Bowtie 4.025” bore x 3.0” stroke-305 cu/in.
RODS- Crower 6”
PISTONS- J.E. 8.25 C.R.
CAM- Crower hyd. roller 114° L.S.- .520” lift.
HEADS- Trickflow G2 - 2.02” int. (275 CFM) – 1.6” exh. (210 cfm)
INTAKE- LOWER Stock, extrude honed.
RUNNERS- A.S.M. TPI
PLENUM- Stock, extensively modified.
THROTTLE BODY- A.S.M. 58 mm.
INDUCTION
TURBO- Innovative GT-76 ball bearing Q-Trim.
INTERCOOLER- Spearco air-to-air with 3” Alum. Tubing
FUEL SYSTEM
FUEL TANK- 1 LE tank with a 255 liter intank pump 5/8” pickup line installed connected to aux. pump
AUX PUMP- Weldon 2025A
LINES - Both pumps into Y-block inlet, single stock 3/8” line on outlet to stock fuel rails thru Weldon press. reg. to 3/8” return line. Aux. pump activated by 1 PSI Hobbs switch. Flow with fuel reg. set at 80 psi@12V is 105 gal/hr at return line.
INJECTORS- Siemens 83 lb inj’s.
E.C.U.
ENGINE- - Electromotive WinTEC 2
TRANSMISSION- TCI T-Com
DRIVETRAIN
CONVERTER- Vigilante 9 ½” 2500 rpm stall with a 5 clutch lockup.
TRANSMISSION -Upgraded 4L80E with tailshaft housing for torque arm
DRIVESHAFT- Denny’s 3 1/2” matrix alum. with 1350 U-joints.
REAR-END- KTRE 12 bolt with Tom’s H.D. Eaton posi and 3.42 gears turning Moser 30 spline axles. 9 ½” alum. brake drums with dual secondary shoes and 1” wheel cyl’s.
RIMS- (F) Weld Pro Star XP 16”x 9”x 5 ½ ” B.S.
(R) Weld Pro Star XP 15”x 9”x 5 ½ “ B.S.
CHASSIS
K-MEMBER- P.A. tubular
SUBFRAME CONN- Global West tubular, welded entire length both sides. Tubular transmission crossmember welded to subframe connectors which moved the instant center back 11”
SUSPENSION
FRONT- Morrison coilovers, Koni adjustable shocks with modified stock lower control arms (better ride). Stock 1 7/16” tubular front swaybar with poly-u Wilwood 12.19” rotors – billet Dynalite calipers – alum. hubs.bushings.
REAR- Boxed stock torque arm (no poly-u bushing and no pinion adj.) Tubular lower control arms.Tubular panhard and upper panhard brace, stock swaybar with Koni adj. shocks.
OTHER
180A Alternater.
Rear mounted drycell battery.
130W Alpine sound system with two 12” woofers. on hinged rear panel.
Power steering, Power brakes, Power windows
Cruise control
Dupont Bright Red metallic, clearcoated finish.
His Old Track Time with a Vortech Supercharger were
STREET / RACE
WEIGHT
3610 lbs / 3600 lbs
(with driver and ¼ tank of fuel)
FRONT / REAR
53/47 / 53/47
(stock 57/43)
BOOST
16 PSI / 25 PSI
FUEL
93 octane / 117 octane
TIRES
(F)BFG 255/50 ZR BFG 255/50 ZR
(R)BFG 275/60 D.R. MT 28/12.5 DOT
PRESENT
10.92@126 / 9.92@136
1.5 60ft / 1.40 60ft
GOAL
10.65@126 / 9.65@140
1.50 60ft / 1.35 60ft
Here are a few pictures I have of his car. Deff. a sleeper!!
http://www.cecoatings.com/images/oth...oCars/preston/
TECH SPEC’S
RODS- Crower 6”
RUNNERS- A.S.M. TPI
INDUCTION
FUEL SYSTEM
E.C.U.
DRIVETRAIN
CHASSIS
SUSPENSION
OTHER
180A Alternater.
Cruise control
STREET / RACE
WEIGHT
3610 lbs / 3600 lbs
FRONT / REAR
53/47 / 53/47
(stock 57/43)
BOOST
16 PSI / 25 PSI
FUEL
TIRES
PRESENT
GOAL
Linson
Aug 21, 2015 02:12 PM
