TPI fuel rail Guage's
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
HI every one..
I would like to know what i need to Install a under hood fuel pressure guage on my TPI set up, ...what guage is OK to use under the hood and what fittings do i need to attach this to the schrader valve , thanks GTA
........ ps a few pics never hurt.
........ ps a few pics never hurt. Thread Starter
Car: 1992 GTA
Engine: running
Axle/Gears: both
Any one??
I did a search, But could not really come up with any thing useful, again pics are worht 1000 words ...hopeing some one has some info for me? thanks GTA..
I did a search, But could not really come up with any thing useful, again pics are worht 1000 words ...hopeing some one has some info for me? thanks GTA.. Member
Car: 1988 IROC-Z
Axle/Gears: 3.45
Car: 1988 IROC-Z
Axle/Gears: 3.45
I found a couple more that might help
https://www.thirdgen.org/techbb2/sho...ssure+gauge%22
Re: TPI fuel rail Guage's
Originally posted by GTA
HI every one..
HI every one..
Car: 1992 GTA
Engine: running
Axle/Gears: both
Brutal... Hi,
I am going to install it under the hood on the schrader valve so making fuel pressure changes will be easier for me, I do realize that having one that I could see at WOT would be better but at this time it is not a option for me, thanks for the reply...
GTA...
GTA... Trending Topics
Just be careful, so you dont have any leakage to cause a fire. Accel, makes a small guage that comes with the things you need to install it. You must remove the pin out of the schrader valve first. Then hook it up and double check the fitting, so you dont cause a fire.
You can just use a diagnostic hand held guage, with a long hose. That way, when the pressure is set, you can verify your results while looking at it taped to the window. Then you can safely install the schrader valve, and thats it.
Sanjay
Aug 12, 2015 03:41 PM
