White smoke coming from '85 Z28
Old Feb 28, 2005 | 08:05 PM
cozhavok's Avatar
Car: 1985 Camaro Z28
Engine: LB9 V8
I just bought a 1985 Camaro Z28 for a whopping $1200 and it has 35,625 on the odometer but I think it's more like 135,625 and everytime I step on the gas it shoots a white cloud of somke out the tail pipes and I feel like James Bond 007. Can you tell me what maybe wrong with it? I aslo am looking for a wiring scheme for the car as it has some wires broke going into the fire wall on the drivers side top the green and orange wire are what are broke. Any help would be great.
Scott
Old Feb 28, 2005 | 08:50 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Is it white smoke or a grey/blue smoke? More then likely if it is grey/blue, you just need to install a new set of valve stem seals. When you start the car after it sits for a few hours, do you get a big puff of smoke?
Old Feb 28, 2005 | 09:08 PM
cozhavok's Avatar
Engine: LB9 V8
When it sits idle just a bit of white smoke but when i hit the gas off of the like it's a big cloud of white smoke. Then it's gome until I hit the pedal again.
Old Mar 2, 2005 | 12:04 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Depending on color, you could have bad ring seal or a popped head gasket. I havn't seen valve stem seals puke so bad it smokes all the time but I'm sure its a possible. I'd check the plugs see if there is a ton of oil on them, or if they're super white (coolant). If its eating coolant, get a cooling sys. pressure tester, put about 15-18 psi in it, and see if bubbles or hissing from intake gasket, maybe sucking coolant into intake ports. If not, you may need to do head gasket(s).
Old Mar 2, 2005 | 12:06 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
I just remembered something else, my friend's 89 GTA did a similar deal only when warm. It was a TPI car but, it had a problem with the intake gasket and was sucking oil through the EGR passage. The thing smoked like a freight train, but only when warm in closed loop. Just an extra thought.
Good luck
Old Mar 2, 2005 | 12:36 PM
Chrome's Avatar
Car: 92' RS Camaro
White = Water...
Head Gasket / Cracked Heads/block
1992rs/ss
16
Jan 28, 2016 09:58 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
neekolzun
Aug 24, 2015 04:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
