Ecm Fuse Amperage?????
Old Mar 6, 2005 | 12:29 AM
kokamo's Avatar
Car: 73' Nova~~~TPI Powered
Engine: 283 Cubic Inch Rev MUNSTER!!
Transmission: Turbo 350
Axle/Gears: GM10 bolt w/4.56 posi
Ok guys, gals, as some of you may know, I am trying to complete a TPI swap into my 73 chevy nova. At the moment I am installing the original wireing harness from my doner car. I am at the point of building my own fuse panel and I need to know some amps on a couple of things.
#1. ECM fuse.....power to the computer when the key is on.
#2. Main wire harness fuse.
#3. Injector fuses.....bank one and bank two.
#4. Fuel pump fuse.
Sorry, I have to ask this question. It just blew right past my mind to grab the fuse box out of my doner car while I was at it.. Now the car is gone and well....here I am.
Thanks!!!!!
Joe
Old Mar 6, 2005 | 01:30 AM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
The Injectors are 10 Amp, Fuel Pump is 20 Amp, ECM is I believe 3 Amp, and I don't believe there is just (1) fuse for the Main Wiring Harness (correct me if I'm wrong). Here's how my Fuse Block is laid out:
1) Computer Command Control - 10 Amp
2) Fuel Injector Feed #1 - 10 Amp
3) Hatch Pulldown Motor - 15 Amp
4) Cooling Fan Relay - 20 Amp
5) Turn Signal Lights;Back-up Lights - 20 Amp
6) MPFI Injectors #2 - 10 Amp
7) Parking Lights;Sidemarker Lights;Taillights - 20 Amp
8) Heater or Air Conditioner - 25 Amp
9) Audio Alarm System;VSS;TCC Brake Switch;Gages;
Rear Window Defogger;Daytime Running Lights - 10 Amp
10) Supplemental Inflatable Restraint - 10 Amp
11) Glove Box Light;Cigarette Lightwe;Hatchback Lid Release;
Horn Relay;Interior Lights;Power Antenna;Power Door Locks;
Radio/Digital Clock;Computer Command Control - 20 Amp
12) Instrument Panel Lights - 5 Amp
13)Radio - 10 Amp
14) Windshield Wiper/Washer - 25 Amp
15) Power Windows - 30 Amp
16) Power Door Locks;Power Seats;Rear Window Defogger - 30 Amp
17) Stoplight Switch;Hazard Flashers;Tone - 20 Amp
18) VATS - 10 Amp
19) Radio - 20 Amp
20) ECM Crank Circuit - 3 Amp
21) Daytime Running Lights - 10 Amp
22) Fog Lights - 20 Amp
This is straight out of the Manual of my 92.
InfernalVortex
Apr 20, 2021 11:31 AM
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
raymondandretti
Sep 27, 2015 06:43 PM
