1.6rr with stock centerbolt covers?
Old Mar 8, 2005 | 04:53 PM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
Hi guys, just as the subject says...
Can I use 1.6rr's with my new 91 vette motor and still be able to use my stock valve covers or any 87+ short style valve cover for that matter. I have heard you can modify the insides of the valve cover to make it work. Anyone have any input on this? I dont know if it matters, but I am using the aluminum vette heads?
Thanks...
Old Mar 8, 2005 | 11:49 PM
postal's Avatar
Engine: hampster in a wheel
Transmission: 700r
Hey usually any rocker besides stockers will hit the webbing in the stock covers .I have seen a few companies make a slim bodied rocker to fit stock covers.I have cut some of the webbing out with snips to gain clearance in the past .I finally just bought new centerbolt covers with no webbing with room for anything im running a set of comp pro magnums no probs..
Old Mar 9, 2005 | 12:08 AM
Abubaca's Avatar
With a stock cam you should be fine. I'm running .510 lift with stock VC's no problem. (with 1.5s)
Same thing right? lift is lift?
Old Mar 9, 2005 | 04:20 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I've got the Crane Gold rockers with my Vette heads and the stock covers. No modifications were required.
Old Mar 9, 2005 | 04:21 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Crane Gold/LT4 HOTCAM roller rockers will clear stock centerbolt valve covers on the cam/bird.
Have them on mine and they clear fine
later
Jeremy
Old Mar 9, 2005 | 06:09 PM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
thanks alot guys!! You are making this much easier, believe me! I'll keep you posted once I buy the rockers and clean the heads up...
Old Mar 9, 2005 | 06:29 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yep, Crane 1.6RR with ZZ9 cam and and stock valve covers. No problem. Allen
Old Mar 9, 2005 | 07:01 PM
H0TR0Dn's Avatar
Car: 88 Formula 350
I have .525 cam with 1.6rr for a total of .560 with no problems
I'llrocya
Feb 2, 2016 11:43 PM
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
mustangman65_79
Aug 8, 2015 01:18 AM
