tpi rebuild help
Old Mar 19, 2005 | 10:53 PM
purplebird's Avatar
Car: 1992 firdbird formula
Engine: 5.7 tpi
tpi rebuild help
I'm in the process of rebuilding my motor. I already have headers, 3.73 gear,chip.i will also be putting underdrive pulleys, msd box and coil on it. I'm getting rid of all the air and all the smog. i'm sticking with the stock heads. i will be putting the accel super ram on it. i will be port matching the heads to the intake and a 3 angle valve job. i will be getting them milled as well. I need a little help on choosing a cam. I want a noticble idle, but nothing to radical and i want a power range inbetween 2-5k. i will be having the block square decked and just honed out. i have a set of light weight corvette piston to go in it. all new seal and ring. So i need to know what cam and lifters to go with this setup amd anything else that you think i will need or need to change.
Thanks a lot
Old Mar 20, 2005 | 05:28 PM
purplebird's Avatar
Engine: 5.7 tpi
?help
Old Mar 22, 2005 | 12:28 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
This will get you started.
http://www.compcams.com/Technical/Cu...ML/128-169.asp
Scroll down the page to their Extreme Energy camshafts about 1/3 of the way down the page and it lists camshafts for 305 and 350 engines. This will let you know the amount of lift, duration and lobe separation angle you should be considering. Then give them a phone call and discuss it with your mechanic.
fbirdroller
Sep 2, 2015 10:27 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 10, 2015 08:42 AM
hokis
Aug 9, 2015 03:57 PM
