Super Ram question
Old Mar 21, 2005 | 09:24 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Super Ram question
I have a friend that has a accel super ram set up that he want's to sell me.. He only has the plenum, runners, base and injectors for it. Question is, i know the chip will have to be recalibrated and i'll need a different fuel pump,but i was wondering if anyone could answer a few questions for me:
1)will my ECM work
2)do i need another distributor
3)will my tpi harness work
4)would my stock throttle body work
5)would i need to get new Oxygen, MAP, IAT ,TPS and IAC sensors
Old Mar 21, 2005 | 09:33 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
It was a direct bolt on for my mass air car. No troubles for me. Longer cold crank time due to eliminating the cold start valve. But it is fine.
Old Mar 21, 2005 | 11:05 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
All your current sensors and throttle body and harness and dizzy will work. You might want a larger TB if you have other mods, but the existing will prolly be fine!
Old Mar 22, 2005 | 12:09 AM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Re: Super Ram question
1)will my ECM work
you can use all the parts you listed 1-5. it will also work with your stock fuel pump and chip
Old Mar 22, 2005 | 11:14 AM
vernw's Avatar
I also don't have the long cranking problem, but then I'm playing with a DIY custom prom as well.
Mine seldom cranks over a second or two before it fires.
Still a little longer when the engine is really warm, but I'm working on it......
Old Dec 18, 2005 | 11:46 PM
Car: 92'Camaro RS
Engine: a loud one
Okay i figure i am going to look for a set up come Jan/Feb.
So what you're saying is i can use my 23 lbs injectors w/ this set up? I thought super ram would need at least 30 to 36 lbs injectors. Which in that case your stock chip wouldn't work.
Old Dec 19, 2005 | 08:01 PM
Shagwell's Avatar
Car: projects.......
an intake swap alone does not warrant larger injectors. You would have to be doing more drastic mods than that to need larger than your factory 22 lb(350 right?) injectors. I've seen plenty of stock injectors on cars making up to about 400 hp.
Old Dec 20, 2005 | 04:22 PM
brutalform's Avatar
HMMM, I wonder why mine does the same? I never had a cold start injector to begin with.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
