140 Amp Alternator worth it??
Old Apr 26, 2005 | 08:34 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Is it worth it getting a 140 Amp Alternator? Does it make that much of difference?? Thanks!
Old Apr 26, 2005 | 09:24 PM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Re: 140 Amp Alternator worth it??
Yes!
I just switch to an 140 amp alt. after the one I had give up. Battery voltage is now staying up ad 14.5V all of time. I can turn on all accessiers at idle and the voltage only falls down to about 13.5V. The car is running smoother etc.
Old Apr 26, 2005 | 10:06 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Which 140amp alternator did you get? Allen
Old Apr 26, 2005 | 10:42 PM
BruceEmbry's Avatar
PowerMaster
Old Apr 26, 2005 | 11:48 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Don't forget the upgrade to the CS144 style alternator:
Old Apr 27, 2005 | 08:28 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Originally posted by BruceEmbry
PowerMaster
Make sure you know which mounting you have . Straight clocking or offset. On the left is offset clocking ( see how the mounting tabs are compared to the other? Right is the straight clocking one.I bought the wrong one first.
Old Apr 27, 2005 | 09:36 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The power Master's are sweet. I got mine and have never seen low voltage or dead batteries.
Old Apr 27, 2005 | 10:09 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Sweeet. The shop I got them from raved about them aswell . I do plan on more electronics in this thing too so I figured the 140 amper is the way to go .
Powermaster rules!!!!! lol
Old Apr 28, 2005 | 10:50 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
All you have to do is take out the 4 bolts, turn the alternator, and reinstall the bolts.
Old Apr 28, 2005 | 11:10 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
nope it doesnt work like that
Old Apr 28, 2005 | 10:39 PM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
wow! those powermasters look sharp
Old Apr 28, 2005 | 10:45 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Yep, especially when you convert to a cs144
Kat
RS Reaper
Oct 17, 2018 07:52 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
bjpotter
Oct 4, 2015 07:48 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
gord327
Oct 3, 2015 01:25 PM
