What causes fuel consumption increase
Old Apr 26, 2005 | 11:23 PM
sam's Avatar
sam
An i mean increase by alot!
Everyone on average seems to get about 17 MPG with their 305 TPI I get 11 which is a big difference.
I changed wires, rotor and cap, platinum plugs, fuel filter, air filter, oil filter.
I must be running rich all the time ? but engine runns smooth thoug all the time.... Would it do that even when running rich?
So have you guys ever had a simillar problem changed what i did and finally changed "the problem" ?
If i am running rich would the car perform much better when it runs as it should
I guess the timing could be out, or maybe the temp sensor for the ecu.
Sam
Old Apr 27, 2005 | 12:31 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Timing out of whack.
Vaccum leak.
Bad injectors.
Bad temp sensor(ecm)
Failing injectors
Clogged catalyst.
I could keep going but those arethe usual obvious ones
Failing MAF(if yours is so equipped)
later
Jeremy
Old Apr 27, 2005 | 12:37 PM
ml258-89iroc's Avatar
Car: 1989 iroc
Axle/Gears: 2.77
My vapor cannister was bad once and caused my fuel milage to go to ****
Old Apr 27, 2005 | 01:35 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Low tire pressure and bad oxygen sensors also....
Old Apr 27, 2005 | 04:17 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Don't put right foot to the carpet. Atleast not all the time.
Old Apr 28, 2005 | 01:19 PM
sam's Avatar
sam
Believe i drive like a nany and get like 11-12 mpg
The car is at the local mechanic being checked out. I will let you know what it turns out to be, if they figure it out.
Btw. will the car go faster with the right fuel mixture ? I mean noticably
Old Apr 28, 2005 | 02:11 PM
kevinc's Avatar
Car: 1982 Z28
It will go slower with the wrong fuel mixture.
Old Apr 28, 2005 | 06:18 PM
sam's Avatar
sam
Got the car back, they had hooked it up to a scanner and it showed that the car is running in open loop all the time. it would go to close loop if you would rev it high and wait a short while.
Then once you let go of the gas it goes to open llop again
They changed the temp sensor for the comp. They said it must be the computer or the prom. Does this sound right?
Reading on the board i hear that going with a heated o2 sensor solves this?
Why is it running open loop all the time, even when engine is nice and warm?
I dont want to spend on a new comp and prom = about 250 when i am not sure that is the problem.
I know the computer has been changed by the previous owner and it is a GM replacement.
Thanks,
Sam
Old Apr 29, 2005 | 04:01 PM
sam's Avatar
sam
one more idea,
since i have headers the o2 sensor is loacted further away then originally could this cause the o2 not to get hot enough causing it to run rich all the time unless reved high?
Please help as i dont want to change a comp and then to find out it was not!
thanks,
Sam
Old Apr 30, 2005 | 02:24 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
You aren't going into closed loop because your o2 sensor isn't getting heated up enough due to the headers.
Easy...replace the o2 sensor with a heated o2 sensor. It should have been done when the headers were installed.
Do a SEARCH on heated o2 sensor...plenty of info for you...
Old Apr 30, 2005 | 05:24 PM
sam's Avatar
sam
Cool, yea i read about it but was not sure
So you think i will acc faster with closed loop?
Old May 1, 2005 | 12:39 AM
Engine: LS3
Transmission: 6L80E
I think that the computer will operate the engine a bit better in closed loop...as GM intended
That way, there is some input to rich/lean as opposed to open loop.
HTH,
customblackbird
Aug 15, 2021 10:16 PM
evilstuie
Feb 28, 2016 03:33 PM
bamaboy0323
Sep 3, 2015 06:07 AM
neekolzun
Aug 24, 2015 04:59 PM
forstral
Aug 19, 2015 03:20 PM
